Status
Not open for further replies.
1 - 2 of 2 Posts
I have one cable run upstairs into one non HD PVR
I have another one run from the basement up the floor.
I have a new HD PVR coming and they are adding an arm to the sat.
What is the best option for me to perhaps get HD upstairs and downstairs.
both TVS are HD.
If you are NOT keeping the 5100/5800/5900's, you will not need to change any cabling as the Tech will use DPP Twin LNBF.
If you are keeping the existing receivers, you will need 2 lines to the location where you plan on putting the HD PVR, The Tech will then use an SW44 at the Dish or just inside the home.
1 - 2 of 2 Posts
Status
