1 - 9 of 9 Posts
The GM-0700 is the model for Shaw Direct. Details are on Winegard's website.
We've got one here, there're actually really easy to set up. It automatically finds the satellite and then automatically switches between F1R and F2 satellites depending on what you're tuned to.
A couple of caveats...
- Based on the size, signal/ebno are lower than you'd see with a full-size dish. HD reception can be hit or miss depending on where you are. Pay attention to the advertised coverage area on the box and product documentation.
- You can connect to two receivers, but the dish itself only aligns to one satellite at a time. If you try to watch an F1R channel on one receiver and an F2 channel on the other, one of the receivers will not have signal.
- This product will not work with the HDPVR 630.
Discussion Starter · #4 ·
The specs say F1 (107) reception only, so it can receive F2 as well?
Heard thru dealer channels that setup is a bitch, trouble with software, so you are saying no problems?
Need to know before I order some for resale, I have some presold just do not want any surprises...thanks.
Hi Sirius Guy,
Since this is a product made by an external company and not sold by Shaw Direct, I can only speak to my personal experiences with the unit we have here.
The one that we have here can indeed get both F1R (107.3) and F2 (111.1). It only aligns to one at a time, but switches between them faster than it takes the receiver to change channels.
Whatever receiver is plugged into the "Primary" coax connection controls which satellite is tuned. If you connected 2 receivers and the "primary" was tuned to F2 and the "secondary" was trying to watch something on F1R, it would just give you no signal (or pull in the equivalent frequency on F2).
When you plug the dish into the power source, it takes upwards of 2 minutes to find the signal. It's all motorized of course, and once it locks on you're good. If you bump/move the dish, it doesn't realign and you have to disconnect/reconnect power to get it aligned again.
The skew must be manually set depending on region, as noted in the product documentation.
Here in Calgary, ebno's were topping out around 5.0 dB on SD channels. Anything 8PSK comes in less than 2.0, which won't provide picture. You might be able to do better with some careful skew adjustment, but I'm not sure if I'd count on that.
I can't speak to which version of software or hardware we've got here but really didn't see any problems with it. Again, this product is manufactured and supported by an external vendor so my knowledge is limited to what we've seen in hands-on usage.
1 - 9 of 9 Posts
