1 - 3 of 3 Posts
I built the single version a few weeks ago. I live in New Port Richey FL. 34653
I am receiving over 40 channels total some which are quite a distance away. What baffles me is my antenna seems to work best at a 90 degree angle to what I believe should be the correct aim which is Southeast. What's up with that?? Signal strength on all channels is over 80. Antenna is 20 ft and I do have a lot of trees around. Single story house.
Hi, can you please generate a TVFool.com report and link to it so that we can see your aiming situation? Just a guess but it's possible that you are so close to the Tampa and/or Orlando stations that they are overloading, so that aiming to the side of them is achieving a suitable level. Again that's just a guess for now.
1 - 3 of 3 Posts
