I'm using mythtv and sdlmame but I cannot get the remote to work with sdlmame to exit, or do the coin insert and player up buttons. I've entered this into my ~/.lircrc file:
#this kills mame - not pretty, but it does the job as SDLMame does not support lirc
begin
prog = irexec
button = ESC
config = killall mame
end
This should exit sdlmame but it does nothing. I've also created entries for other buttons but they do not work either.
I've done some reading that indicate I might need to use xmacro-warp but I'm not sure. IS anyone else using a remote with sdlmame?
begin
prog = irexec
button = ESC
end
