1 - 4 of 4 Posts
Hello I have a Garmin Nuvi 255W GPS. Software version 6.60. I live in Canada and want to know how to get junction map view? I have seen websites explaining to downgrade software to V2.30 but the file is no longer available. Has anyone had success that can help me out?
Not Sure that your unit has that function
I'm not certain that the 255 can show junction view. I know that on the 1490T that I have does show it. You should look up the specs on your unit.
according to Garmin's page:
nüvi 255W features junction view of intersections and exits
I would contact Garmin tech support on this matter
As far as I can dig up junction view on the 255W is only supported on the Singapore/Malaysian model, which has specific firmware.
Apparently there is a way to get it to work on the 255W by loading different firmware, and I was able to dig up instructions after a minute of googling.
1 - 4 of 4 Posts
