1 - 4 of 4 Posts
Greetings
Does anyone know if it is possible to copy the address data from one unit over to the another?
I have a nuvi 680 first and then I added the nuvi 765 unit. I'd like to transfer the data over to the new unit without typing all the data in ... person by person.
Looked in the directories of both units and nothing jumps out as something I can just copy and paste.
thanks
Regards
I'm new to the GPS world, but when you hook up the device via USB to the computer, you can see various files on your computer that are on the GPS. One of these probably relates to the addresses in the GPS - Favourites, Home, Recent, etc. You may be able to copy this file(s) to the computer and then transfer it/them to the new GPS, however, it may or may not be compatible.
Suggest you contact Garmin - perhaps they even have an FAQ on this on their website.
Discussion Starter · #4 ·
Greetings
Thank you for contacting Garmin International. It will be my pleasure to assist you with this.
In order to transfer your favorites from your old Garmin device to your new Garmin device you will need to follow the steps below:
Instructions for a PC:
1. Connect your Garmin device to your computer using a data transfer USB cable.
2. Double-click on My Computer or Computer.
3. Right-click on the Garmin device drive and select Open.
4. Locate and double-click the GPX Folder. (On some devices you may need to open the Garmin Folder first then the GPX Folder)
5. Right-click and copy the Current.gpx file.
6. Locate your computer's Desktop.
7. Right-click and select Paste to save the Current.gpx file onto your Desktop.
To send the file to the new GPS, please follow the steps below:
1. Right-click on the Current.gpx file on your Desktop and select Rename.
2. Name the file Current1.gpx and then press Enter.
3. Right-click on the Current1.gpx file and select Copy.
4. Connect your device to your computer.
5. Double-click on My Computer or Computer.
6. Right-click on the Garmin device drive and select Open.
7. Locate and double-click the GPX Folder. (On some devices you may need to open the Garmin Folder first then open the GPX Folder)
8. Right-click and select Paste.
9. Disconnect your device from your computer and allow it to boot up.
Your favorites will now be restored on your device.
Instructions for a Mac:
1. Connect the Garmin device to the Mac using a data transfer USB cable.
2. Double-click on the Garmin device when you see it mounted to the Desktop.
3. Locate and double-click the GPX Folder. (On some devices you may need to open the Garmin Folder first then open the GPX Folder)
4. Right-click and copy the Current.gpx file.
5. Right-click on your Mac's Desktop and select Paste to save the Current.gpx file onto the Desktop.
To send the file to the new GPS please follow the steps below:
1. Right-click on Current.gpx file on your Desktop and select Get Info.
2. Under Name & Extension, rename the file Current1.gpx and press Enter.
4. With Garmin device connected to the Mac, double-click on the Garmin Drive.
5. Locate and double-click the GPX Folder. (On some devices you may need to open the Garmin Folder first then open the GPX Folder)
6. Right-click and paste the Current1.gpx file into the GPX folder on your Garmin device.
Your favorites will now be on your new device.
Please feel free to reply to this email, or call 1-800-800-1020,
if you require further assistance.
Works like a charm. It keeps both files ... new and old. Had to go through to prune a bit.
1 - 4 of 4 Posts
