This was the surprise at Photokina. It will be available in March for around $1k.
http://www.marketnews.ca/LatestNewsHeadlines/FujifilmIntrosRetro-ChicAPS-CCompactatPhotokina.html
Hybrid Viewfinder New Development
The Hybrid Viewfinder on the FinePix X100 combines the window-type “bright frame” optical viewfinder found in high-end film cameras such as 35mm or medium-format cameras, and the electronic viewfinder system incorporated in fixed single lens or mirrorless digital cameras. By integrating a prism for the 1,440,000 dot LCD panel image on the viewing screen in the reverse-Galilean optical finder, the Hybrid Viewfinder can show both the shooting frame and a variety of shooting data.
It can also be used as a high-quality electronic viewfinder to compose or playback shots, with the ability to instantly switch between optical and electronic viewfinder images with simple “one touch” control. The new Hybrid Viewfinder offers users expanded freedom in the composition and enjoyment of photography in a range of challenging shooting conditions.
12.3 Megapixel APS-C CMOS Sensor
The FinePix X100 features a custom CMOS high-performance sensor, internally optimized and developed exclusively for this model.
Optimization of the angle-of-incidence in conjunction with the specially developed lens maximizes light gathering efficiency extending to the perimeter of the sensor for a sharper image with exceptional clarity.
23mm F2 Fujinon (Aspherical) Lens
The newly-developed lens offers a focal length of 23mm (135 equivalent: 35mm) and a widest aperture of F2. Made from moulded glass, the lens contains 8 elements in 6 groups.
The adoption of the non-collapsible lens structure with minimized lens length not only contributes to the compact size but also eliminates telescoping of the lens when the power is on. It’s ready to start shooting the moment you turn it on.
Featuring a built-in ND filter (equivalent f-stop reduction of 3), the lens can enhance depth-of-field even in bright shooting conditions by enabling the aperture to be kept wide open. Shutter speed can also be reduced to capture waterfalls, or any shot where intentional blur is required.
