Anyone know where to get FTA equipment; such as LNB?
My equipment is getting old.
2025 CDN$50 = 2010 CDN$34...$50 CDN. Less than half what I paid for the S9 15 years ago.
Received my V9 this morning. Now the fun begins. My dish motor is out of alignment, and its way to hot to be out in the sun.2025 CDN$50 = 2010 CDN$34
So you actually paid less than 1/3 of what you paid in 2010. A spanking good deal. And the technology in the V9 Prime is superior to an S9 from 2010.
I can view approx 70 to 125W. I moved the dish/motor about 8 feet higher. Now I can't find Gal 19. Its a no brainer. Can't figure out what I am doing wrong. It scanned OK before I moved it! Will try again tomorrow morning.Go outside about before 7:00 am or after 8:00 pm. Should be more hospitable. What range can your dish view when using the motor? Mine where it is can see 150W through 82W now. I've had a fixed dish on 81W, 78W and 77W. Not a lot to see from those.
After a lot of wasted time I locked in 97W. Somehow my S9 LONG setting changed from west to east. So the motor was confused. Never the less when I blind scanned 97W, I lost a few transponders. I'm only scanning in 38 channels rather than the the usual 95 or so. The Q is 83 and S is 70. I still need to tweak the dish a bit better.Tree? Or house overhang? 97W transponders have disappeared. Still trying for an active transponder? Didn't change receiver LO setting? Turned off power at receiver to LNB? Connection tight at receiver/LNB?
So you bought from a US source? Not from China?Well,
I just got a text that my receiver has been delivered... to an unknown (to me) address in Logan, Utah....
Or not, considering the current political situation. I've had similar things happen with Canada Post due to labour disputes.Very weird.
