1 - 7 of 7 Posts
FOX W Channel 291 off air
I haven't been able to tune into Fox W HD 291 for a few months now. It just says it's "acquiring satellite signal". How do I switch polarity and what do I switch it to? Right now both tuners are set at L_H. And if I switch the polarity would this solve the problem?
I am also not able to tune to this channel on my 530 as well.
Yep - I had this a few years ago - I think it was the exact same channel. I thought for sure it was my multi-switch, then a bad cable. But for some reason I decided to swap out some F6 connectors. Everything came back and has been good since. So try changing some connectors first.
1 - 7 of 7 Posts
