cypo said:
Is there a less conspicuous directional antenna that I can use on a rotor mounted outside for good reception?
Hmmm. Maybe I could try and answer this another way.
The APS-9 is a large FM YAGI style antenna? Correct? Large and very conspicuous. Many elements. The APS-9 is directional by nature (its a YAGI ?). Lots of gain in one direction. So you'd have to get it up in the air and point it in the right direction. You mention a rotor.
A
single horizontal dipole, with no reflectors or directors is directional too. Receives best from two directions. In front and behind the dipole. And has a pretty wide beamwidth. Little gain. (figure 8 pattern / figure 8 plot).
-Simple. Not too conspicuous. One horizontal element.
(but it's best to get that up in the air, on a pole)
Horizontal Dipole and one Reflector. When you add one horizontal reflector, you make it directional in ONE direction, and add some gain from that direction, and some rejection from the back.
- More conspicuous. Two horizontal elements and a beam.
(still, it's best to try and get it up in the air, on a pole)
There are also other less conspicuous antennas:
Vertical Dipole. Omni-directional - receives from all directions - no need to point it. I've seen some designs of these - they just look like a vertical pole, or vertical wires with insulators and support structure.
If a vertical pole, or whip antenna works well enough, its not very conspicuous ... if designed / built / installed properly...and if you can get it up high ... that might work too. Depends.
examples. Car antenna. VHF whip. 1/4 wave vertical ground plane antenna. Mounted outside, high for good reception. But has to be designed for FM. Correct length for FM and properly matched to the transmission line and receiver.
- ALSO -
The Straight Dipole (half wave dipole) mounted vertically.
Two pieces of tube or rod, correct lengths for FM.
( I've heard they work pretty good for FM ... if mounted outside, high up. And not very conspicuous. Omnidirectional. No need for rotor. Might even be able to mount that off the side of a tower, pole or building - the side that faces the FM transmitter(s) of interest.)
Google Search: FM Dipole Antenna
They show lots of images and ideas for the FM Dipole antenna.
Maybe something like this? FM Vertical Dipole?:
http://fmdxantenna.com/proddetail.php?prod=FMDipUS
