Hello,
I have an old Harmony H659 -- I've decided it's incompatible with the FibeTV box.
It's the Harmony H659 (the first ever Harmony remote, SST-659) from before Logitech bought Harmony -- the H659 has worked perfectly with all consumer devices until FibeTV. I try to teach the H659 to control the FibeTV box, using the usual method that has always worked, and the FibeTV box (Motorola VIP1232) doesn't respond to the H659 remote for commands I've manually taught to the H659 remote from the FibeTV remote.
What other newer Harmony Remotes work with FibeTV?
I am a fan of most Logitech Harmony Remotes (except for Harmony One, which isn't designed to be disassembled for cleaning sticky buttons and reported to break easily upon disassembling-for-cleaning -- so boycotting that specific model -- other Harmony models are easier to disassemble, according to Logitech forums. If I spend over $100 on a remote control, it better allow me to disassemble it for an annual cleaning of sticky stuff from rubber buttons!)
