1 - 3 of 3 Posts
Hi, I have just switched to FIBE , and am having one helluva time trying to program my Harmony remote to match the "options" button. I have tried most of the generic commands , and have had the remote "learn" the options code many times, but it still won't access the options when it is pressed.
Are there better codes to use other than for the VIP 2262? A different model number that would work? It is the only code that I can't seem to get to work, and it seems from first glances it may be one of the more used commands.
If anyone can help, I will really appreciate it!
Have you tried the Enter button on the bottom right of the Harmony. I programmed a Harmony 650 with the older VIP boxes and that worked (I don't think I had to do any special programming).
Discussion Starter #3
Wow! that was it. The last button I expected to be "options".
Thanks for your help!
1 - 3 of 3 Posts
