1 - 5 of 5 Posts
Thank god I found this forum.
It seems like Bell doesn't really know what is my problem. They are either sending me a new modem or a tech guy to check my connection, which solve absolutely nothing.
Here is my problem, I am really looking forward to fix this issue.
I am on the Bell 25 Fibe service.
My modem is: Alcatel Lucent 7130
I am streaming to a site called justin.tv
I am using a broadcasting program called Dyyno.
My broadcast rate is 3MPBs.
After a certain time, lets say 45 minutes to 1 hour, my internet connection is completely interrupted, there is no more connectivity to the internet, on all computers using this connection.
I have to manually reset the modem so I can connect to the internet again.
I have been speaking with Dyyno tech support to run a debug mode on the program, I thought at first the problem came from there.
We managed to record the entire behavior of the program and its not from there.
I have had this problem occur also just with normal uploads. Ex: Uploading videos to the internet.
After a few hours of uploading the modem completely stall and I have to reboot it.
All the lights on the modem are always green, DSL, Internet etc.
Bell tech supports tells me after reviewing my connection that I never lost connection to the central and that everything is smooth on their end.
I am convinced that this problem come from the modem.
Has anyone encountered this issue? Did you manage to fix it? and how!
I would love to know how I can manage this problem.
If any wizard out there knows how to fix this, ll'l owe you a beer or bottle of wine of your choice if you can help me out!
Thanks in advance
Discussion Starter · #2 ·
I have found the solution.
If you ever do encounter this problem, here is the solution.
Speak with a Bell tech support about lowering slightly your user profile.
Your profile is about the speed on which your connection operate.
I was set at 26 MBPS Down 7. something UP
After talking to someone with the same problem, the solution was just really to lower the connection speed just a little.
Everything is back to normal since then.
I think I am sitting at 24 mbps down and 6. something Up
It took me a few tries untill I found the perfect Profile ( with a Tech Support ).
Initially when they changed my profile the downgrade was huge, I was down at 3 MBPS for my upload speed.
So yeah, I called them back and tweaked the profile as high as I could and kept my connectivity intact during Upload stress.
Here is the exact name of the profile :
v26944-26944_8128-1600_82412
You just have to ask them to switch it to this!
This is the perfect profile for any user who put the modem under heavy upload stress.
Enjoy! :)
Discussion Starter · #5 ·
The problem you described can be fixed with the appropriate profile! Just call them up and ask them to switch profile to the one I gave above.
It's exactly what was happening to me.
I beleive the problem comes from the booster in the modem.
Anyways, switching profile will fix everything. Good luck
1 - 5 of 5 Posts
