1 - 2 of 2 Posts
Purchased direct from the manufacturer in June 2007, this beast is in full working order and cosmetically is in excellent condition. It doesn't support HDMI unfortunately but would be a fine receiver for other equipment - a projector for example. Includes remote and manual. $250 obo.
Features:
•DTS-ES Discrete and Matrix, DTS-96/24, DTS NEO-6
•Dolby Digital EX, Dolby Pro Logic IIx fully adjustable, Dolby Virtual Speaker, Dolby Headphone
•192 kHz 24-bit DAC's for all channels
•Analog Bypass mode for all inputs
•Quadruple Crossover Control (Separate settings for Front L/R, Center, Surround L/R, Surround Back L/R)
•Upgradeable via RS-232
•Transcoding between composite, S-Video and Component Video Inputs
•4 Optical and 4 Coaxial Digital Inputs
•Optical and Coaxial Digital Output
•Lip Synch Delay
•On Screen Display (via composite, S-Video and Component)
•32-Bit CS-49400 Crystal Processor
•7.1 channel direct input with full digital bass management, analog bass management and pure by-pass
•2-channel subwoofer offset
•7.1 RCA pre-amp outputs
•High performance tuner
•Direct access station tuning via remote control
•30 Station Presets
•IR control with 1 inputs and 1 output
•2 Video Record Out Selectors
•12-Volt Trigger
•3 HD capable Component Video Inputs
•2 DVI Inputs 1 DVI Output
•5 Audio/Video Inputs
•4 Audio Inputs
•Channel Level Memory
•Sleep Timer
•Aluminum Front Panel
•Dimensions: (HxWxD): 5.9 " with feet x 17.2" x 15.5"
•Weight: 40 lbs.
1 - 2 of 2 Posts
