1 - 8 of 8 Posts
I imagine that ananlog channel 2 Bancroft will be transitioning to digital channel 8 within a year or two, so it might not be worthwhile to put too much effort into a channel 2 antenna.
The Winegard HD8200U specs already has 7 dBd listed as the channel 2 gain. Thats a lot of gain for channel 2. If you arent getting channel 2 now with it, a db or so more isnt likely to help.
http://www.winegarddirect.com/viewi...latinum-VHFUHFFM-HDTV-Antenna-(HD8200U)&post=
I think you could get more channel 2 gain with it by having a boom extension on the back, and putting on a 120 inch reflector rod. Obviously this will make the antenna pretty unwieldy and you would have to use at least a 1/2 inch diameter reflector rod. You would also need to brace the back of the antenna more.
Discussion Starter · #5 ·
Channel 2
Just for clarification it's Channel GBL North Bay not Bancroft. Haven't heard anything about looming change to digital.
Shaw promised the CRTC that they would transition all of Global's transmitters by Aug 31, 2016, so that is a few years off, but worth keeping in mind.
Having said that, I have a lead on a 10Y2S (Cut Channel Yagi for channel 2) which would provide 10dB gain. If that doesn't work, nothing will.
Discussion Starter · #8 ·
Channel 2 reception
On second thought, I think I'm being a little bit picky about the Global reception. It's just a bit weak compared to the others, and it should be - its the furthest transimitter that I'm pulling a signal from. I also identified a faulty splitter that was really hurting my reception... I'm definately not going to add a new antenna with a 17+ feet boom!
Thanks for all the suggestions though..
1 - 8 of 8 Posts
