Step-by-step instructions to build from scratch the least expensive, fully functional HD PVR for Digital and Analogue TV with easy to find, brand new PC hardware and minimal computer knowledge:
- Download one of these free MythTV PVR OSes (they contain all the software you will need: drivers, media players, video editors, transcoders, photo apps, digital camera and camcorder apps, music apps, rippers, burning software, bittorrent, sharing, etc.):You do not need to know Linux to set those up since they guide you through the whole setup process. If you do run into problems there is a ton of help and info on the web. You do not need to buy any other software!
- Buy PC hardware that is going for clearance prices. You do not need the latest/greatest ($$$) hardware for a fully functional HD PVR
- Based on your OS choice above, read its hardware compatibility list then select your hardware. They support most hardware out there, so do not buy an unsupported device!
Checklist of brand new hardware (cost estimates are based on small PC parts wholesaler lists August 8, 2009):- basic standard PC case including ~450w power supply (~$70)
- DVD burner (~$25)
- keyboard (~$10)
- mouse (~$10)
- dual core CPU (AMD Athlon64 X2 5200 or Intel Pentium Dual 5300) (~$80)
- basic, simple motherboard with dual-channel memory (~$80)
- 4GB of ram (~$60)
- 1 small hard drive <100GB for OS (~$50)
- 2 or more large SATA hard drives >500GB for video storage (~$60 each)
- graphics card with HDMI and/or Component out for feeding an HDTV @1080p (~$50)
- audio card with SPDIF digital and/or TOSLINK optical out for feeding surround sound receiver @ DD7.1 (~$30)
- LAN device (~$20-$60)
- tuner/capture devices:
- PCI
- PCI-E
- USB 2.0 (~$90 each for Hauppauge 950Q)
- NTSC (~$25 each for Hauppauge 150 PCI)
- ATSC
- Clear QAM
- S-Video in
- Composite in
- RF in
- Additional notes:
- This adds up to ~$650 before taxes for the whole thing in separate parts
- most small PC shops will bundle several of the items at an even lower price
- some low cost motherboards come with LAN and SPDIF onboard
- Likely you'd want 2 or more each of ATSC and NTSC devices to allow multiple channel recording
- Other devices can be added, such as multi-card readers, Firewire, Bluetooth, etc. to suit your needs.
- Local network clients of your new HD PVR include PCs, Macs, XBoxes, and other extenders
