1 - 2 of 2 Posts
Hi - First timer on the forum and looking for a little insight.
I just got a TiVo and have set it up with my MTS TV. The Tivo instructions are geared toward traditional cable providers (not IP such as MTS). To their credit, MTS tech support was able to help me with a couple of the issues and I have the Tivo working, but only as a single tuner.
Does anyone have the Tivo dual-tuner functionality working with MTS TV and if so, how did you set it up ?
The second tuner can only work on analogue cable, so I think you're out of luck with your IP provider since I assume it needs a STB. Plenty of similar discussions if you search from TiVo on this site.
1 - 2 of 2 Posts
