1 - 4 of 4 Posts
Ok guys have a friend who bought a Bell system back in 2002 approx
He is now going to HD...I had a spare Dual LNB holder and gave it to him....
Problem .....His Dish that the LNB would bolt to is curved on the top side like the LNB......... the one I gave him is rectangular at the point where it would mount to the Dish but the LNB's are correct....
Is his Dish an old style that has an arch on the mounting shaft ???
Can he get a Dual LNB holder that will mount onto the arched mounting shaft....????
thanks for any help guys.....Chris
That Dish will not support the "Y" yolk for holding 2 x Dual LNBF's.
I can only imagine that for some reason an 18" Dish was used, or a 24" one but either way if the arm is "D" shaped it is not made for aiming at 2 orbital locations. There will also be NO skew adjustment on that Dish, which is required for correct aiming at 2 Satellites.
The dual LNB holder will only work with a Bell 20"dish. It's best to get the entire dish.
1 - 4 of 4 Posts
