1 - 14 of 14 Posts
When analogue ends in Canada will stations be switching down to their original VHF frequencies - ie. Will CBC Toronto DT drop from channel 20 to channel 5?
If so does this mean that I will require a VHF antenna to supplement my 4221?
Is there a thread that discusses this?
In the main OTA Forum are threads giving DTV transition updates on the status of each of the major Canadian networks or smaller groups of stations and independents. Check for "Transition Status" in the thread title. When the CRTC approves a station's license we find out the real channel from that approval, then we wait for Industry Canada to authorize the station to occupy that channel.
Since channel assignments have changed throughout this process we have not kept a "chiselled in stone" list of what they'll be in each city. Here's Industry Canada's lists, updated every day:
http://www.user.dccnet.com/jonleblanc/Canada_TV_Stations/
CBLT's post transitional allotment is channel 20.
One other thing to consider is while many stations will use VHF-HI (channels 7-13) post transition, very few stations will use VHF-LO (channels 2-6). There are some exceptions however (most notably Global's repeaters in both Paris and Ottawa will continue to use channel 6).
In most markets a VHF-HI antenna will be required, but this is much smaller than an antenna that covers all VHF channels. As stampeder said, check either the Industry Canada list or alternately the Canadian Government's DTV page.
Discussion Starter · #4 ·
So at the Government's DTV page it lists the following for Toronto:
CBC Toronto (CBLT-TV-1)
Analog Channel: 16
Transition Plan: Shutting down, August 31, 2011
CBC Toronto (CBLT)
Analog Channel: 5
Digital Channel: 20
Transition Plan: Digital transmitter operational – analog shutdown, August 31, 2011
What is CBLT-TV-1?
So to get VHF-HI channels like CFTO, which will be at channel 9, will require an additional antenna vs. my 4221 antenna? Can I use two different antennas and use a combiner?
That's what the Reception threads are for - you can get detailed info in them on how your neighbours are doing and also seek advice from our experienced members.
This isn't the thread for it Wayne, but we'll keep assisting you over here with your questions about Scarborough OTA reception: ON - Scarborough, Pickering, Ajax, Whitby, Oshawa - OTA
For newcomers here's how to begin finding the present and future OTA DTV stations in your area:
http://www.digitalhome.ca/forum/showthread.php?t=125161
Why are some channels still on VHF?
I was under the impression that the OTA broadcasters weren't entirely interesting with the move to digital, and that the deal finally got done by closing down everything outside channels 20 to 59 and selling off the bandwidth for big bucks.
But here we are long after the transition, and I'm getting inputs on everything from 14 to 66 on the UHF side, and even stranger, there's lots of VHF across the dial. What happened to the plan? Is it still in motion, or are we stuck with combo antennas?
Somehow you have been misinformed.
Ch2-51 (minus Ch37) are STILL legal TV channel allocations throughout North America.
Although the UHF high end MAY shrink sometime in the near future....
Although Lo-VHF has man-made noise and monster user antenna problems, it's still
the long-range, low transmitter ERP & hence much less expensive to operate alternative...
As Analog stations converted to Digital, DTV viewers in Canada are scrambling
for VHF (esp. Hi-VHF) antennas, since Analog channels are no longer "sitting"
on the VHF channel allocations.
I'm not sure where you got your numbers from. The plan was always to consolidate to 2-51, although it was acknowledged in Canada that VHF-Low was pretty useless, and any allocations on VHF-low would be mostly on 5 and 6.
Many broadcasters that were on VHF-High for NTSC stayed on VHF-High because:
  • they could reuse the same antenna plant,
  • sometimes even parts of the transmitter plant,
  • coverage in hilly areas is better on VHF-High
  • power consumption requirements were allegedly lower, although many are finding they need higher power to get equivalent in-building coverage in urban areas.
There are still some 52 to 69 holdouts and that's why you see something on 66 in Toronto. It will be gone in a couple of weeks. It got special permission to stay on the 66 for 2 months as CKXT will be defunct November 1.
There are also a number of CBC repeaters in mandatory DTV markets in this range too and at the moment have permission to continue to August 31, 2012. I understand that CBC will again apply to extend this - we'll have to see what the CRTC (and IC too I'd guess) says about that?! :eek:
I thought the extension CBC received was only to continue broadcasting in analog in certain mandatory markets (where they have a repeater instead of an originating station). They had applied to move repeaters on channels 52-69 to lower frequencies, did this not happen?
1 - 14 of 14 Posts
