1 - 6 of 6 Posts
Hi all, hope you can help.
I have a Yamaha RX-V565 receiver hooked up via hdmi to a Sony BDP-S350 bluray player.
Until recently, I would always see DTS-HD, for those applicable bluray discs, and the receiver and sound would reflect it.
Now I can't make any change to the receiver when playing a DTS-HD disk as it only says "Straight".
Any help in getting the correct settings would be appreciated.
Discussion Starter · #6 ·
Spoke with Yamaha and the solution was so simple as I had the correct settings all along.
I had pressed the "INFO" button on the Yamaha remote which changed what was being viewed on front of the panel.
By selecting Audio Decoder (3 of 3), it now shows the audio signal name such as Dolby TrueHD, HD-DTS etc.
Hope this helps anyone who has the same issue.
1 - 6 of 6 Posts
