1 - 2 of 2 Posts
Is it possible to used the DPP Quad LNB and use 3 or 4 DPP separators to support up to said amount of dual tuner PVR's? So far it seems from reading some things that it can only support 2 Dual Tuners and 2 regular tuners.
I don't think a DPP quad exists. You can use the DPP twin and attach a DPP33 or DPP44 switch though. Each output of the twin or the switch can support either a single or dual tuner receiver (using a separator) or any combination of the two. So a DPP44 switch will support four dual tuner PVR's, if that's what you want.
-Mike
1 - 2 of 2 Posts
