Of course, you will need a router you can also use a wifi router as an access point it is better to use your old sell it you can cover your entire house with two routers by using as an access point
I use pfsense for my firewall router. It's far more capable that SOHO routers. I have a separate Unifi access point.The open source software used for dedicated routers is usually updated quickly when security vulnerabilities are found.
