After you have carefully put together your homemade antenna, how do you connect it to the mast? I've seen several antennas built onto the mast but I haven't seen many where they attach to the side of the mast.
Here is my current connection for a 3/4" PVC pipe to a 1" mast. There is a 3/4" metal self tapping screw holding the T to the PVC (via 300ohm?). I would use one set on the top and the bottom.
Is there a better way or am I on the right track?
David
David
