I see threads in this forum and others all the time asking how to hide wires and speaker cables etc. Besides fishing them inside the walls using fish-tape, from the bottom of the wall to the speaker, there are other methods to route them from your AV rack to the speaker locations. The 2 methods I used are as follows:
1 - Wiremold (wire raceway):
This is a type of conduit that you can open up, place your low voltage cables in, and then snap closed. You can either use screws to fix it to the wall or peel 'n stick method using the adhesive backing on it. It comes in a few different colors, but you can paint to match. In my case, I used leftover wall paint to color them before I installed them. The stuff I used in the pictures below in from a different generation. There are inside corner pieces, outside corners, T-junctions, 90 degree, etc, that you can buy and snap over your joints. I was unable to get these to fit the wiremold I had, but the corner is behind the bar fridge and doesn't matter. There are different sizes depending on how much wire you need to fill it with. I used the large stuff around the baseboards, and the smaller ones for wall installation. There are a few places where I could not fish wires inside the walls, for instance, on the outside corner of a wall where there are wood beams on the corner. I used a full piece all the way to the ceiling even though the wire only goes up as high as the speaker:
That is the Surround left speaker of a 7.1 system. As you can see, I made a "T" junction out of the wiremold, and made a hole in the side of the vertical piece using a utility knife.
Along the bottom, I removed the trim (see below) and routed the wire behind it, and then I notched the back of the trim using a file and a utility knife so the speaker cable could make the corner on the inside. So there is a vertical notch in the trim piece about an inch from the end, right where the wiremold starts, making the wire completely invisible:
I have more pictures in my albums.
Now, the horizontal pieces of wiremold. You can see on the right the mess of wires that otherwise would be running around the floor. Notice the colors. In the second picture, you can see the corner...try to imagine snapping in a corner piece to cover the crack:
