1 - 20 of 65 Posts
Now that I am happy with my OTA reception and receiving all the available channels for my area, I am moving to my next project to improve my wi-fi
can the bowties array or SBGH or DBGH be adapted for 2.4 GHz wifi?
how about the balun? can the 300 to 75 ohm balun be used?
Could you provide me with a few leads
thanks
Simple Wifi Antenna
I made this simple wifi antenna based on the wavelength of the 2450mhz frequency.
According to 4nec2X it can get up to 3.57 dB and as low as -15 dBi.
I'm not sure why exactly sure how I can have negative dBis, but I do.
So, I'm probably gonna add this onto my old wifi adaptor and see what happens.
Also, sorry about posting it in this forum, its just the best place I could think of doing this.
So, comments? Opinions
Taylor :)
Code:
1
                                    NUMERICAL ELECTROMAGNETICS CODE (NEC-2D)
                                     - - - - COMMENTS - - - -
                          Model: expt5 for MURS (omni)
                          parms = [3.08888, 3.945, 35.099, 8.53386, 10.9385, 3.05447, ];
                          A1: 3 1/16 in.
                          A2: 3 15/16 in.
                          B1: 8 9/16 in.
                          B2: 35 1/8 in.
                          C: 10 15/16 in.
                          D: 3 1/16 in.
                          Wire diameter: 0.0640837
                          COM: (0 in., 8 5/16 in., 0 in.)
                          BBOX: dX=0, dY=10.9385, dZ=90.3202
                          COM Turning radius: 8.31024
                          Min Turning radius: 5.46925
                                 - - - STRUCTURE SPECIFICATION - - -
                                     COORDINATES MUST BE INPUT IN
                                     METERS OR BE SCALED TO METERS
                                     BEFORE STRUCTURE INPUT IS ENDED
  WIRE        NO. OF    FIRST  LAST     TAG
  NO.        X1         Y1         Z1          X2         Y2         Z2      RADIUS   SEG.     SEG.   SEG.     NO.
     1   -0.06120    0.00000    0.00000     0.06120    0.00000    0.00000    0.00129      1        1     1       1
     2   -0.06120    0.00000    0.00000    -0.06120    0.12236    0.00000    0.00129      1        2     2       2
     3   -0.06120    0.12236    0.00000     0.06116    0.12236    0.00000    0.00129      1        3     3       3
     4    0.06120    0.00000    0.00000     0.06120    0.12236    0.00000    0.00129      1        4     4       4
   TOTAL SEGMENTS USED=    4     NO. SEG. IN A SYMMETRIC CELL=    4     SYMMETRY FLAG=  0
         - MULTIPLE WIRE JUNCTIONS -
 JUNCTION    SEGMENTS  (- FOR END 1, + FOR END 2)
  NONE
                                 - - - - SEGMENTATION DATA - - - -
                                        COORDINATES IN METERS
                         I+ AND I- INDICATE THE SEGMENTS BEFORE AND AFTER I
  SEG.   COORDINATES OF SEG. CENTER     SEG.     ORIENTATION ANGLES    WIRE    CONNECTION DATA   TAG
  NO.       X         Y         Z       LENGTH     ALPHA     BETA      RADIUS    I-   I    I+    NO.
     1   0.00000   0.00000   0.00000   0.12240    0.00000   0.00000   0.00129    -2    1    4      1
     2  -0.06120   0.06118   0.00000   0.12236    0.00000  90.00000   0.00129    -1    2    3      2
     3  -0.00001   0.12236   0.00000   0.12238    0.00000   0.00000   0.00129     2    3   -4      3
     4   0.06119   0.06118   0.00000   0.12236    0.00000  90.00937   0.00129     1    4   -3      4
 ***** DATA CARD NO.  1   EX   0     1     1     0  1.00000E+00  0.00000E+00  0.00000E+00  0.00000E+00  0.00000E+00  0.00000E+00
 ***** DATA CARD NO.  2   GN  -1     0     0     0  0.00000E+00  0.00000E+00  0.00000E+00  0.00000E+00  0.00000E+00  0.00000E+00
 ***** DATA CARD NO.  3   FR   0     1     0     0  2.45015E+03  0.00000E+00  0.00000E+00  0.00000E+00  0.00000E+00  0.00000E+00
 ***** DATA CARD NO.  4   RP   0     1    73  1001  9.00000E+01  0.00000E+00  1.00000E+00  5.00000E+00  0.00000E+00  0.00000E+00
                                 - - - - - - FREQUENCY - - - - - -
                                    FREQUENCY= 2.4502E+03 MHZ
                                    WAVELENGTH= 1.2236E-01 METERS
                    APPROXIMATE INTEGRATION EMPLOYED FOR SEGMENTS MORE THAN   1.000 WAVELENGTHS APART
                               - - - STRUCTURE IMPEDANCE LOADING - - -
                                   THIS STRUCTURE IS NOT LOADED
                                  - - - ANTENNA ENVIRONMENT - - -
                                            FREE SPACE
 PIVOT(  4)=  1.94796439E-11
                                - - - MATRIX TIMING - - -
                        FILL=    0.000 SEC.,  FACTOR=    0.000 SEC.
                                          - - - ANTENNA INPUT PARAMETERS - - -
   TAG   SEG.    VOLTAGE (VOLTS)         CURRENT (AMPS)         IMPEDANCE (OHMS)        ADMITTANCE (MHOS)      POWER
   NO.   NO.    REAL        IMAG.       REAL        IMAG.       REAL        IMAG.       REAL        IMAG.     (WATTS)
     1     1 1.00000E+00 0.00000E+00 4.03144E-04-9.98782E-04 3.47511E+02 8.60952E+02 4.03144E-04-9.98782E-04 2.01572E-04
                             - - - CURRENTS AND LOCATION - - -
                                 DISTANCES IN WAVELENGTHS
  SEG.  TAG    COORD. OF SEG. CENTER     SEG.            - - - CURRENT (AMPS) - - -
  NO.   NO.     X        Y        Z      LENGTH     REAL        IMAG.       MAG.        PHASE
     1    1   0.0000   0.0000   0.0000  1.00033   4.0314E-04 -9.9878E-04  1.0771E-03  -68.019
     2    2  -0.5002   0.5000   0.0000  1.00000   4.8334E-04 -1.0261E-03  1.1342E-03  -64.776
     3    3  -0.0001   1.0000   0.0000  1.00016   2.7167E-04 -1.8429E-04  3.2828E-04  -34.152
     4    4   0.5001   0.5000   0.0000  1.00000  -1.2082E-03  2.5043E-03  2.7805E-03  115.756
                                        - - - POWER BUDGET - - -
                                           INPUT POWER   = 2.0157E-04 WATTS
                                           RADIATED POWER= 2.0157E-04 WATTS
                                           STRUCTURE LOSS= 0.0000E+00 WATTS
                                           NETWORK LOSS  = 0.0000E+00 WATTS
                                           EFFICIENCY    = 100.00 PERCENT
                                                - - - RADIATION PATTERNS - - -
  - - ANGLES - -           - POWER GAINS -       - - - POLARIZATION - - -    - - - E(THETA) - - -    - - - E(PHI) - - -
  THETA     PHI        VERT.   HOR.    TOTAL      AXIAL     TILT   SENSE     MAGNITUDE    PHASE      MAGNITUDE    PHASE
 DEGREES  DEGREES       DB      DB      DB        RATIO     DEG.              VOLTS/M    DEGREES      VOLTS/M    DEGREES
   90.00     0.00    -999.99  -12.15  -12.15    0.00000   -90.00  LINEAR    3.27138E-13    29.68    2.71460E-02   -61.64
   90.00     5.00    -999.99  -12.52  -12.52    0.00000   -90.00  LINEAR    3.18752E-13    52.13    2.60219E-02   -40.82
   90.00    10.00    -999.99  -13.92  -13.92    0.00000   -90.00  LINEAR    2.96841E-13    73.40    2.21443E-02   -35.82
   90.00    15.00    -999.99  -15.15  -15.15    0.00000   -90.00  LINEAR    2.63102E-13    91.16    1.92199E-02   -56.61
   90.00    20.00    -999.99  -11.84  -11.84    0.00000   -90.00  LINEAR    2.18186E-13   100.51    2.81138E-02   -86.80
   90.00    25.00    -999.99   -7.06   -7.06    0.00000   -90.00  LINEAR    1.81464E-13    91.04    4.87900E-02   -96.05
   90.00    30.00    -999.99   -3.29   -3.29    0.00000   -90.00  LINEAR    2.28493E-13    65.38    7.52299E-02   -94.89
   90.00    35.00    -999.99   -0.53   -0.53    0.00000   -90.00  LINEAR    3.94537E-13    55.16    1.03402E-01   -90.18
   90.00    40.00    -999.99    1.43    1.43    0.00000   -90.00  LINEAR    6.37972E-13    57.08    1.29543E-01   -84.12
   90.00    45.00    -999.99    2.69    2.69    0.00000   -90.00  LINEAR    9.23241E-13    62.71    1.49834E-01   -77.42
   90.00    50.00    -999.99    3.31    3.31    0.00000   -90.00  LINEAR    1.21526E-12    68.94    1.60944E-01   -70.27
   90.00    55.00    -999.99    3.31    3.31    0.00000   -90.00  LINEAR    1.47467E-12    74.52    1.60871E-01   -62.51
   90.00    60.00    -999.99    2.69    2.69    0.00000   -90.00  LINEAR    1.66178E-12    78.83    1.49789E-01   -53.56
   90.00    65.00    -999.99    1.51    1.51    0.00000   -90.00  LINEAR    1.74349E-12    81.39    1.30781E-01   -42.18
   90.00    70.00    -999.99    0.04    0.04    0.00000   -90.00  LINEAR    1.70037E-12    81.64    1.10432E-01   -26.45
   90.00    75.00    -999.99   -0.98   -0.98    0.00000    90.00  LINEAR    1.53302E-12    78.63    9.82578E-02    -5.73
   90.00    80.00    -999.99   -0.76   -0.76    0.00000    90.00  LINEAR    1.26884E-12    70.50    1.00700E-01    14.47
   90.00    85.00    -999.99    0.28    0.28    0.00000    90.00  LINEAR    9.76437E-13    53.15    1.13602E-01    26.65
   90.00    90.00    -999.99    1.34    1.34    0.00000    90.00  LINEAR    7.96961E-13    21.14    1.28290E-01    29.70
   90.00    95.00    -999.99    2.08    2.08    0.00000    90.00  LINEAR    8.79089E-13   -16.34    1.39632E-01    25.51
   90.00   100.00    -999.99    2.50    2.50    0.00000    90.00  LINEAR    1.13979E-12   -42.68    1.46587E-01    15.77
   90.00   105.00    -999.99    2.72    2.72    0.00000    90.00  LINEAR    1.41277E-12   -60.40    1.50318E-01     1.78
   90.00   110.00    -999.99    2.82    2.82    0.00000    90.00  LINEAR    1.60978E-12   -74.65    1.52191E-01   -15.18
   90.00   115.00    -999.99    2.84    2.84    0.00000    90.00  LINEAR    1.69501E-12   -87.88    1.52375E-01   -33.90
   90.00   120.00    -999.99    2.68    2.68    0.00000    90.00  LINEAR    1.66219E-12  -101.17    1.49737E-01   -53.55
   90.00   125.00    -999.99    2.28    2.28    0.00000    90.00  LINEAR    1.52494E-12  -115.01    1.42889E-01   -73.82
   90.00   130.00    -999.99    1.55    1.55    0.00000    90.00  LINEAR    1.30969E-12  -129.58    1.31365E-01   -94.82
   90.00   135.00    -999.99    0.48    0.48    0.00000    90.00  LINEAR    1.04879E-12  -144.87    1.16146E-01  -116.85
   90.00   140.00    -999.99   -0.88   -0.88    0.00000    90.00  LINEAR    7.73996E-13  -160.63    9.93220E-02  -140.10
   90.00   145.00    -999.99   -2.43   -2.43    0.00000    90.00  LINEAR    5.11645E-13  -176.08    8.31484E-02  -164.25
   90.00   150.00    -999.99   -4.05   -4.05    0.00000    90.00  LINEAR    2.80876E-13   171.37    6.89929E-02   171.82
   90.00   155.00    -999.99   -5.72   -5.72    0.00000    90.00  LINEAR    1.01966E-13   179.02    5.69235E-02   150.09
   90.00   160.00    -999.99   -7.49   -7.49    0.00000   -90.00  LINEAR    1.01312E-13  -102.32    4.63988E-02   132.81
   90.00   165.00    -999.99   -9.36   -9.36    0.00000   -90.00  LINEAR    2.00860E-13  -100.35    3.74221E-02   122.00
   90.00   170.00    -999.99  -11.01  -11.01    0.00000   -90.00  LINEAR    2.73242E-13  -114.67    3.09523E-02   118.48
   90.00   175.00    -999.99  -11.93  -11.93    0.00000   -90.00  LINEAR    3.14130E-13  -132.04    2.78355E-02   119.32
   90.00   180.00    -999.99  -12.14  -12.14    0.00000   -90.00  LINEAR    3.27134E-13  -150.28    2.71638E-02   118.18
   90.00   185.00    -999.99  -12.22  -12.22    0.00000    90.00  LINEAR    3.17555E-13  -168.49    2.69365E-02   110.71
   90.00   190.00    -999.99  -12.43  -12.43    0.00000    90.00  LINEAR    2.91596E-13   174.38    2.62796E-02    94.78
   90.00   195.00    -999.99  -12.23  -12.23    0.00000   -90.00  LINEAR    2.56183E-13   160.51    2.68787E-02    68.67
   90.00   200.00    -999.99  -10.46  -10.46    0.00000   -90.00  LINEAR    2.21914E-13   154.31    3.29891E-02    37.04
   90.00   205.00    -999.99   -7.31   -7.31    0.00000   -90.00  LINEAR    2.15351E-13   160.58    4.73912E-02    10.68
   90.00   210.00    -999.99   -4.05   -4.05    0.00000   -90.00  LINEAR    2.80557E-13   171.41    6.89578E-02    -8.15
   90.00   215.00    -999.99   -1.28   -1.28    0.00000   -90.00  LINEAR    4.30429E-13   173.82    9.48503E-02   -22.31
   90.00   220.00    -999.99    0.87    0.87    0.00000   -90.00  LINEAR    6.46170E-13   169.51    1.21448E-01   -34.00
   90.00   225.00    -999.99    2.38    2.38    0.00000   -90.00  LINEAR    9.03249E-13   162.75    1.44609E-01   -44.31
   90.00   230.00    -999.99    3.28    3.28    0.00000   -90.00  LINEAR    1.17122E-12   155.76    1.60343E-01   -53.88
   90.00   235.00    -999.99    3.57    3.57    0.00000   -90.00  LINEAR    1.41339E-12   149.59    1.65773E-01   -63.16
   90.00   240.00    -999.99    3.26    3.26    0.00000   -90.00  LINEAR    1.59144E-12   144.81    1.60091E-01   -72.76
   90.00   245.00    -999.99    2.42    2.42    0.00000   -90.00  LINEAR    1.67238E-12   141.91    1.45260E-01   -83.60
   90.00   250.00    -999.99    1.21    1.21    0.00000   -90.00  LINEAR    1.63600E-12   141.45    1.26403E-01   -97.06
   90.00   255.00    -999.99    0.12    0.12    0.00000   -90.00  LINEAR    1.48155E-12   144.36    1.11404E-01  -114.09
   90.00   260.00    -999.99   -0.19   -0.19    0.00000    90.00  LINEAR    1.23483E-12   152.52    1.07584E-01  -132.21
   90.00   265.00    -999.99    0.41    0.41    0.00000    90.00  LINEAR    9.62128E-13   169.84    1.15287E-01  -145.36
   90.00   270.00    -999.99    1.34    1.34    0.00000    90.00  LINEAR    7.96928E-13  -158.86    1.28291E-01  -150.30
   90.00   275.00    -999.99    2.16    2.16    0.00000    90.00  LINEAR    8.74143E-13  -122.43    1.40910E-01  -147.73
   90.00   280.00    -999.99    2.74    2.74    0.00000    90.00  LINEAR    1.11811E-12   -96.15    1.50793E-01  -139.28
   90.00   285.00    -999.99    3.14    3.14    0.00000    90.00  LINEAR    1.37418E-12   -78.01    1.57768E-01  -126.45
   90.00   290.00    -999.99    3.37    3.37    0.00000    90.00  LINEAR    1.55704E-12   -63.20    1.62058E-01  -110.50
   90.00   295.00    -999.99    3.43    3.43    0.00000    90.00  LINEAR    1.63157E-12   -49.29    1.63190E-01   -92.42
   90.00   300.00    -999.99    3.26    3.26    0.00000    90.00  LINEAR    1.59182E-12   -35.19    1.60055E-01   -72.76
   90.00   305.00    -999.99    2.80    2.80    0.00000    90.00  LINEAR    1.45149E-12   -20.35    1.51777E-01   -51.61
   90.00   310.00    -999.99    2.01    2.01    0.00000    90.00  LINEAR    1.23680E-12    -4.55    1.38594E-01   -28.70
   90.00   315.00    -999.99    0.91    0.91    0.00000    90.00  LINEAR    9.79481E-13    12.29    1.22135E-01    -3.60
   90.00   320.00    -999.99   -0.41   -0.41    0.00000    90.00  LINEAR    7.10332E-13    30.06    1.04885E-01    23.98
   90.00   325.00    -999.99   -1.83   -1.83    0.00000    90.00  LINEAR    4.54385E-13    48.31    8.90223E-02    53.84
   90.00   330.00    -999.99   -3.29   -3.29    0.00000    90.00  LINEAR    2.28836E-13    65.40    7.52868E-02    85.09
   90.00   335.00    -999.99   -4.85   -4.85    0.00000    90.00  LINEAR    4.80202E-14    59.19    6.29179E-02   116.82
   90.00   340.00    -999.99   -6.68   -6.68    0.00000   -90.00  LINEAR    1.09551E-13   -50.53    5.09490E-02   149.15
   90.00   345.00    -999.99   -8.85   -8.85    0.00000   -90.00  LINEAR    2.13170E-13   -35.38    3.96898E-02  -176.17
   90.00   350.00    -999.99  -10.94  -10.94    0.00000   -90.00  LINEAR    2.80866E-13   -14.75    3.11823E-02  -136.78
   90.00   355.00    -999.99  -12.03  -12.03    0.00000   -90.00  LINEAR    3.16767E-13     7.19    2.75112E-02   -95.37
   90.00   360.00    -999.99  -12.15  -12.15    0.00000   -90.00  LINEAR    3.27138E-13    29.68    2.71460E-02   -61.64
 ***** DATA CARD NO.  5   EN   0     1    73  1001  9.00000E+01  0.00000E+00  1.00000E+00  5.00000E+00  0.00000E+00  0.00000E+00
 RUN TIME =     0.000
Why waste your time on a measley 3.57 dbi ? That only a bit better than a cheap rubber ducky antenna. With a Bi-Quad, about as easy a build as you can get, you get 10+ dbi. And the radiation pattern is balloon like, horizontally and vertically, so its very easy to aim. (you could actually mount it at any angle thats handy)
http://martybugs.net/wireless/biquad/
detailed analysis here :
http://www.lecad.uni-lj.si/~leon/other/wlan/biquad/
A bi quad NEC file is in the 4nec2 models folder.
My older build of it:
I have since built a better one with the lips, and tweaked it out with Netstumbler (free windows program, but nothing like it in linux) in real time. Tweaking in real time is a real necessity with 2+ Ghz, because even blowing on it changes things, heh.
Im now considering building a 18dbi 3D corner reflector antenna from here :
http://yu1aw.ba-karlsruhe.de/vhf_ant.htm
Of course, if I wanted some real gain of 24+ dbi, I could put my bi quad in front of the large Dish TV network parabola I found along side the road, heh. On the other hand, I get a constant full 5 bars now with the bi quad, at -48 to -50 dbm and can pick up a couple of the neighbors wifi's at over 800 ft, heh.
I dont know what connector your WiFi card is using, but all mine use reverse SMA. Cheapest price I found here : http://www.newegg.com/Product/Product.aspx?Item=N82E16833998053
Its RG-58U cable, so not quite the ultra lowest loss cable out there despite their claims, heh.
I have these pci wifi cards, and they work well :
http://www.newegg.com/Product/Product.aspx?Item=N82E16833180030
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166020
Hmm, I actually really liking that last one, RamKat. Just wondering, can I use something cheap like... err... tin foil instead of all that expensive copper?
Also, RamKat, I was just installing that antenna in the attic today. Don't worry, I'm slow but, I'm getting it done. ;)
Taylor
Looks great! But the problem is it's not omni directional. I have seen those before, and you know what, I will look more into them.
Hmm, so youre looking for antenna for the wireless router itself, for roaming around with a laptop ? If so, you probably want a larger vertical rubber ducky like this one :
http://www.newegg.com/Product/Product.aspx?Item=N82E16833998041
One of the best things I did for my wifi setup was to move the location of where the router was originally located, even though it involved 50 ft of cat 6 and 50 ft of RG6. (I have a FIOS setup)
Keep in mind, with a carefully planned directional antenna setup, you can make it harder for others to pick up your signal. (security concerns, heh)
Not a bad price, but I think I'll check out something-bay. I was looking at one it was 3.50 for 12 dBi. I'm sure it's a little higher rated than it's actual power LOL, but we'll see.
Ok, so maybe for omni-directionality, buying is the best solution, unless someone has any other tips.
Now, could anyone recommend a solution for super point to point, as everyone seems to know lots about this, roaming around town (by town I mean a few km2 of fields). I was looking at a few yagis, but couldn't find any comparable DIY projects. You know what, scratch that. What is truly the best way to do directional (as in house roof too house roof, or just house roof to a focused area in town you are a lot like a coffee place).
What do you guys use?
Also, sorry if there are topics for this, I couldn't find anything really related to this, but anyone is welcome to point me in the right direction. :D
Sorry if I'm starting to have really complicated posts. It's late for me LOL.
Thanks!
Taylor
As I noted above (look for some links, I think the world record is a few hundred miles, with legal equipment). An old dish (relatively smallish dish) with a bi quad (or some similar high gain feed point antenna) is pretty awesome.
Yeah, the cost of the connectors, unless buying in 10,000's, will kill us.
Yeah, I was looking at some of those biquads, they look great. Now, I have a 33" dish with a busted arm, and I know you can use dishes to create something super directional. Now, I can easily attach a rod to the dish to fix the arm, but when aiming the dish vertically, how can I know what angle the signal heading towards?
Thanks!
Taylor
Coffee can and Pringles can wifi antennas have been around for years and achieve very good results. Other people have used modified satellite dishes. Five miles distance or more is quite common and it has been used to extend internet access to unserved areas by many people. There was an annual contest to see who could get the longest range with a standard, unamplified signal. They were up to about 20 miles the last I read.
My WiFi Antennas - work very well
Here the instructions:
http://www.digitalhome.ca/forum/album.php?albumid=350&pictureid=1551
Here are the picture:
http://www.instructables.com/id/8226-12-dBi-Colinear-Wi-Fi-Antenna-with-60H-x-
http://www.flickr.com/photos/[email protected]/3973232534/in/photostream/
Here is the listing of 8 dBi omni base station antenna (downsweep 0* ~ -15* could be adjusted by flattening the ground wiskers):
NOte: I had to remove the middle portion of the antenna model to fit in one post.
CE
GW 66 11 0 0 2.5e-3 0 0 0.0655 2.5e-4
GW 67 1 0 2.6e-3 0.0665 9.75655e-4 2.40593e-3 0.066625 2.5e-4
GW 68 1 9.7565e-4 2.40589e-3 0.066625 1.8028e-3 1.85329e-3 0.06675 2.5e-4
GW 69 1 1.8028e-3 1.85329e-3 0.06675 2.3554e-3 1.02615e-3 0.066875 2.5e-4
GW 70 1 2.35544e-3 1.02615e-3 0.066875 2.54951e-3 5.049e-5 0.067 2.5e-4
GW 71 1 2.54951e-3 5.049e-5 0.067 2.35544e-3 -9.2517e-4 0.067125 2.5e-4
GW 72 1 2.3554e-3 -9.2521e-4 0.067125 1.8028e-3 -1.7525e-3 0.06725 2.5e-4
GW 73 1 1.8028e-3 -1.7525e-3 0.06725 9.7565e-4 -2.3045e-3 0.067375 2.5e-4
GW 74 1 9.75655e-4 -2.3049e-3 0.067375 0 -2.499e-3 0.0675 2.5e-4
GW 75 1 0 -2.499e-3 0.0675 -9.7566e-4 -2.3049e-3 0.067625 2.5e-4
GW 76 1 -9.757e-4 -2.3045e-3 0.067625 -1.803e-3 -1.7525e-3 0.06775 2.5e-4
GW 77 1 -1.803e-3 -1.7525e-3 0.06775 -2.355e-3 -9.2521e-4 0.067875 2.5e-4
GW 78 1 -2.3554e-3 -9.2517e-4 0.067875 -2.5495e-3 5.049e-5 0.068 2.5e-4
GW 79 1 -2.5495e-3 5.049e-5 0.068 -2.3554e-3 1.02615e-3 0.068125 2.5e-4
GW 80 1 -2.355e-3 1.02615e-3 0.068125 -1.803e-3 1.85329e-3 0.06825 2.5e-4
GW 81 1 -1.803e-3 1.85329e-3 0.06825 -9.757e-4 2.40589e-3 0.068375 2.5e-4
GW 82 1 -9.7566e-4 2.40593e-3 0.068375 0 2.6e-3 0.0685 2.5e-4
GW 83 1 0 2.6e-3 0.0685 9.75655e-4 2.40593e-3 0.068625 2.5e-4
GW 84 1 9.7565e-4 2.40589e-3 0.068625 1.8028e-3 1.85329e-3 0.06875 2.5e-4
GW 85 1 1.8028e-3 1.85329e-3 0.06875 2.3554e-3 1.02615e-3 0.068875 2.5e-4
GW 86 1 2.35544e-3 1.02615e-3 0.068875 2.54951e-3 5.049e-5 0.069 2.5e-4
GW 87 1 2.54951e-3 5.049e-5 0.069 2.35544e-3 -9.2517e-4 0.069125 2.5e-4
GW 88 1 2.3554e-3 -9.2521e-4 0.069125 1.8028e-3 -1.7525e-3 0.06925 2.5e-4
GW 89 1 1.8028e-3 -1.7525e-3 0.06925 9.7565e-4 -2.3045e-3 0.069375 2.5e-4
GW 90 1 9.75655e-4 -2.3049e-3 0.069375 0 -2.499e-3 0.0695 2.5e-4
GW 91 1 0 -2.499e-3 0.0695 -9.7566e-4 -2.3049e-3 0.069625 2.5e-4
GW 92 1 -9.757e-4 -2.3045e-3 0.069625 -1.803e-3 -1.7525e-3 0.06975 2.5e-4
GW 93 1 -1.803e-3 -1.7525e-3 0.06975 -2.355e-3 -9.2521e-4 0.069875 2.5e-4
GW 94 1 -2.3554e-3 -9.2517e-4 0.069875 -2.5495e-3 5.049e-5 0.07 2.5e-4
GW 95 1 -2.5495e-3 5.049e-5 0.07 -2.3554e-3 1.02615e-3 0.070125 2.5e-4
GW 96 1 -2.355e-3 1.02615e-3 0.070125 -1.803e-3 1.85329e-3 0.07025 2.5e-4
GW 97 1 -1.803e-3 1.85329e-3 0.07025 -9.757e-4 2.40589e-3 0.070375 2.5e-4
GW 98 1 -9.7566e-4 2.40593e-3 0.070375 0 2.6e-3 0.0705 2.5e-4
GW 99 1 0 2.6e-3 0.0705 9.75655e-4 2.40593e-3 0.070625 2.5e-4
GW 100 1 9.7565e-4 2.40589e-3 0.070625 1.8028e-3 1.85329e-3 0.07075 2.5e-4
GW 101 1 1.8028e-3 1.85329e-3 0.07075 2.3554e-3 1.02615e-3 0.070875 2.5e-4
GW 102 1 2.35544e-3 1.02615e-3 0.070875 2.54951e-3 5.049e-5 0.071 2.5e-4
GW 103 1 2.54951e-3 5.049e-5 0.071 2.35544e-3 -9.2517e-4 0.071125 2.5e-4
GW 104 1 2.3554e-3 -9.2521e-4 0.071125 1.8028e-3 -1.7525e-3 0.07125 2.5e-4
GW 105 1 1.8028e-3 -1.7525e-3 0.07125 9.7565e-4 -2.3045e-3 0.071375 2.5e-4
GW 106 1 9.75655e-4 -2.3049e-3 0.071375 0 -2.499e-3 0.0715 2.5e-4
GW 107 1 0 -2.499e-3 0.0715 -9.7566e-4 -2.3049e-3 0.071625 2.5e-4
GW 108 1 -9.757e-4 -2.3045e-3 0.071625 -1.803e-3 -1.7525e-3 0.07175 2.5e-4
GW 109 1 -1.803e-3 -1.7525e-3 0.07175 -2.355e-3 -9.2521e-4 0.071875 2.5e-4
GW 110 1 -2.3554e-3 -9.2517e-4 0.071875 -2.5495e-3 5.049e-5 0.072 2.5e-4
GW 111 1 -2.5495e-3 5.049e-5 0.072 -2.3554e-3 1.02615e-3 0.072125 2.5e-4
GW 112 1 -2.355e-3 1.02615e-3 0.072125 -1.803e-3 1.85329e-3 0.07225 2.5e-4
GW 113 1 -1.803e-3 1.85329e-3 0.07225 -9.757e-4 2.40589e-3 0.072375 2.5e-4
GW 114 1 -9.7566e-4 2.40593e-3 0.072375 0 2.6e-3 0.0725 2.5e-4
GW 115 1 0 2.6e-3 0.0725 9.75655e-4 2.40593e-3 0.072625 2.5e-4
GW 116 1 9.7565e-4 2.40589e-3 0.072625 1.8028e-3 1.85329e-3 0.07275 2.5e-4
GW 117 1 1.8028e-3 1.85329e-3 0.07275 2.3554e-3 1.02615e-3 0.072875 2.5e-4
GW 118 1 2.35544e-3 1.02615e-3 0.072875 2.54951e-3 5.049e-5 0.073 2.5e-4
GW 119 1 2.54951e-3 5.049e-5 0.073 2.35544e-3 -9.2517e-4 0.073125 2.5e-4
GW 120 1 2.3554e-3 -9.2521e-4 0.073125 1.8028e-3 -1.7525e-3 0.07325 2.5e-4
GW 121 1 1.8028e-3 -1.7525e-3 0.07325 9.7565e-4 -2.3045e-3 0.073375 2.5e-4
GW 122 1 9.75655e-4 -2.3049e-3 0.073375 0 -2.499e-3 0.0735 2.5e-4
GW 123 1 0 -2.499e-3 0.0735 -9.7566e-4 -2.3049e-3 0.073625 2.5e-4
GW 124 1 -9.757e-4 -2.3045e-3 0.073625 -1.3759e-3 -1.339e-3 0.07375 2.5e-4
GW 125 1 -1.3759e-3 -1.339e-3 0.07375 -1.e-3 -4.e-4 0.0739 2.5e-4
GW 126 1 -1.e-3 4.e-4 0.0661 -1.4e-3 1.3e-3 0.06625 2.5e-4
GW 127 1 -1.4e-3 1.3e-3 0.06625 -9.757e-4 2.40589e-3 0.066375 2.5e-4
GW 128 1 -9.7566e-4 2.40593e-3 0.066375 0 2.6e-3 0.0665 2.5e-4
GW 129 1 -1.e-3 4.e-4 0.0661 0 0 0.0655 2.5e-4
GW 130 1 -1.e-3 -4.e-4 0.0739 0 0 0.0745 2.5e-4
GW 131 11 0 0 0.0745 0 0 0.1375 2.5e-4
GW 782 11 0 0 0.8665 0 0 0.9295 2.5e-4
GW 1 1 0 0 -1.25e-3 0 0 2.5e-3 2.5e-4
GW 783 25 0 0 -1.25e-3 0.125 0 -0.075 2.5e-4
GW 784 25 0 0 -1.25e-3 0.08838835 0.08838835 -0.075 2.5e-4
GW 785 25 0 0 -1.25e-3 0 0.125 -0.075 2.5e-4
GW 786 25 0 0 -1.25e-3 -0.0883884 0.08838835 -0.075 2.5e-4
GW 787 25 0 0 -1.25e-3 -0.125 0 -0.075 2.5e-4
GW 788 25 0 0 -1.25e-3 -0.0883884 -0.0883884 -0.075 2.5e-4
GW 789 25 0 0 -1.25e-3 0 -0.125 -0.075 2.5e-4
GW 790 25 0 0 -1.25e-3 0.08838835 -0.0883884 -0.075 2.5e-4
GE 0
EK
EX 0 1 1 0 1 0
GN -1
FR 0 1 0 0 2440 0
1 - 20 of 65 Posts
