1 - 2 of 2 Posts
We are in Palm Springs and only want to see the 91 sat. While we can find the signal on 91 with our 20 inch dish we can not get the signal strong enough to lock on. Is there a larger dish I could use? Any thing I could buy in California or Arizona? Any help is appreciated.
Just about any dish will work. You just need the right type of LNB. (DBS with circular polarity, same as Dish Network.) A lot of people use 1m or larger dishes in low signal areas. You might want to look for reception reports from other people in your area. Southern California is a bit tricky with some people having having good luck and others not getting a signal on all transponders.
1 - 2 of 2 Posts
