21 - 25 of 25 Posts
anyway, I will be installing the new lnb this weekend.......I have them connected via 5x8 multiswitch.
If you are converting from a stacked lnb, you will have some additional cabling issues if you plan on re-using the multiswitch. ( ie: you will need additional runs from the lnb to the switch). Converting from the non-stacked lnb should be a simple matter of swapping cables.
21 - 25 of 25 Posts
