This is a question to all the OTA gurus on this forum.
I would like to design custom antenna for my location,
based on the numbers given by tvfool.
The weakest channel I'd like to get is 23 (ION) and for this I'd probably need a preamp.
By looking at the tvfool chart I've come up with a list of frequencies, azimuths and target gains.
My question are:
Are the target gains enough (with /without preamp)?
Are some if target gains to much if I am to use a preamp?
Could I go with less gain on any channel?
Thanks in advance,
nikiml
My question are:
Code:
Chan Network Dist Path NM azim target gain
(mi) (dB) (deg) (dbi)
20 CBC 19.8 LOS 49.6 50 0
18 Ind 26.2 LOS 46.7 -50 0
40 19.8 LOS 44.4 50 0
44 OMN 20.2 LOS 43.1 50 0
64 OMN 20.2 LOS 41.6 50 0
35 Ind 26.2 LOS 38.6 -50 0
24 SRC 19.8 LOS 37.4 50 0
32 CW 57.6 LOS 37.2 0 0
65 GTN 19.8 LOS 34.9 50 0
66 Sun 19.8 LOS 34.8 50 0
53 Ind 19.8 LOS 33.5 50 0
43 PBS 57.6 LOS 29.5 0 1
14 Fox 57.5 LOS 24.2 0 1
39 CBS 86.2 LOS 21.7 -5 1
33 NBC 85.4 1Edge 17.5 0 5
38 ABC 87.5 1Edge 12.9 -5 8
26 Ind 87.1 1Edge 11.5 -30 9
49 MyN 86.3 1Edge 7.7 0 10
7 Ind 88.0 2Edge -7.2 -10 8
23 ION 100.2 2Edge -13.5 10 16
nikiml
