1 - 5 of 5 Posts
Sorry if this has been asked! I'm just wondering if there is any way to wipe out the recorded shows or select multiple shows to delete at one time? I have 100 shows recorded and I hate hate hate having to delete them individually. :( Ideas?
I appreciate it!
Thank you
Laura
Hi Laura
I've found the easiest way to delete multiple shows is to use the delete button. I use 1 thumb on the delete button and 1 thumb on the OK button, so it goes fairly quickly.
The version of Mediaroom that Telus is using doesn't have the capability to delete multiple shows at once. There is a newer version that allows you to delete all the shows for a series, but I don't know when Telus will implement it.
I find it way easier to do it on line. The remote recording app allows you to delete recordings and I like this a lot more than using my actual remote while sitting in front of the TV.
Actually, I do all my recording setup etc on line now.
1 - 5 of 5 Posts
