1 - 4 of 4 Posts
I just got a Yamaha RXV467 ,how can I tell if I'm hearing HD sound it doesn't seam to give info on the display my old receiver would show DD,DTS,etc.
· Super Moderator
It should show you on the front display, however, you also need to be connected correctly and have the device sending the signal (BD Player?) properly configured to send bitstream to the AVR. See the following thread - read the part near the end on HD/HDMI audio.
http://www.digitalhome.ca/forum/showthread.php?t=76082
If you have an older PS3 (not the slim model), then it cannot bitstream HD audio to the AVR via HDMI, so you need to set it to send PCM and then the AVR will indicate Multi-channel PCM on the front. If there is no such indication, in the AVR's user menu there is usually an info option which shows you the incoming signal.
Also, on the PS3 the "display" button will indicate what's happening in the PS3.
thanks I have the old ps3,I have it set to bitstream and I found the info function when I choose dtshdor ddhd it reads dts or dd .I'll try it at pcm
Discussion Starter · #4 ·
Ok set it to PCM display on ps3 reads dts-hd 5.1 48khz receiver reads PCM thanks again
1 - 4 of 4 Posts
