1 - 4 of 4 Posts
Hi, would anyone happen to know what happened to the "add a recording/view scheduled recordings" option in the quick menu when you hit the um settings button.
I went to set something up earlier today but couldnt find it. Unless im blind i dont know.
So I had to do it the long way and go through the menu find the show I wanted then add a recording.
I know it was there last night cause I had to use it then.
If they did take it away I dont like it cause now I have to search through the menu to find whatever it is I want to change channels/record. I also have no clue of what I have set up to switch/record unless I go through the guide which is kinda tiresome. =(
This was an unforseen change unfortunately. Shaw is currently working with Rovi (TV Guide Manufactorer) and expects to have this corrected later this week or next. IN 209600 is Shaw's ticket for tracking
1 - 4 of 4 Posts
