Got back from work yesterday and found my HD box with no display, when it usually shows the time, which is the way I have it set up. Blank. I turn the TV on and I eventually get the light grey service menu screen and it asks me for my PIN. I enter it and the picture comes on. But no menu and no guide available. And it takes time to switch from one channel to another (~5 secs). And no sound from the TV speaker. My car pool buddy tells me he gets still gets sound through his HT setup although he gets none via TV speaker...Doing the power disconnect reboot doesn't change anything.
Called Rogers Tech Support. If you want to talk to an actual person, it automatically sends a re-authorization (which never hit the box) and then tells you that because of technical difficulties, tech support is not avaliable. Call back later.
Called my French buddies, got an actual person and found out Rogers updated the DCT6200 to correct the sound off/not authorized problem and it screwed everything up. Said it would be 24 - 48 hours before it would be cleared up. He said this only affects DCT6200 boxes. Problem is, with no sound and no access to the menu to clear the problem, I'm stuck with video only until they send the fix.
As reported in another thread, I've had issues many times before where the sound would be muted when I turn the box on. Adjusting the Menu, Sound option, back and forth between fixed and variable clears it up. A minor annoyance, but one my wife couldn't fix on her own. The odd channel also comes up as unauthorized (like Channel 7 earlier this week), but if you stay on that channel long enough, it comes back.
