Hi,
Got home today and the box is not working.
Symptoms:
1. On the number display it will blink one pixel (in between the third and forth non lit 8 on the number display.
2, Periodically it will flash the 4 eights for about 5 seconds then go back to the one pixel. When it does this you can hear the fan or hard drive start up for a second.
3. After awhile the display read "oob".
I have restarted the box many times and called shaw. they could not see it on the network and can't get a tech out until the 30th of Oct. I have a ton of shows on the pvr that i do not want to loose.
Please i need help. Is there away to reset the box manually? any help would be greatly appreciated.
Symptoms:
