1 - 4 of 4 Posts
I'm about to upgrade my Cogeco service to 1Gb, which will involve returning the DOCSIS 3.0 cable modem to Cogeco, retiring my Asus router, and going with the Cogeco-supplied current router. I have Internet service only, no TV, so don't care about MOCA capabilities. I understand that Cogeco is sometimes supplying the HiTron unit, and sometimes an Arris unit. I have heard and read both good and bad things about both. I do not want to use bridge mode and keep using my own router. This is all part of simplifying home technology configurations for my spouse, as I quickly fade with ALS.
With that context, I'm wondering if anyone can report on current experiences (within the last 6 months to a year) with Cogeco's current modem/routers. Which one,HiTron or Arris, has better Wi-Fi performance (range, speed) and which one is likely to be more reliable?
(I've got lots of technical background, so please don't worry about technical answers.) Thank you.
One thing to consider about using only their equipment is you'll only get a single /64 IPv6 prefix. If you provide your own router and use bridge mode, you can have up to 256 /64s, assuming your router supports it.
Each /64 contains 2^64 or 18.4 billion, billion addresses.
thanks. Given my goal is simplification, and the context for doing so, that limitation is not a consideration.
Discussion Starter · #4 ·
To close out my interest in this thread, I'll share that a couple of weeks ago I upgraded my Cogeco Internet service and replaced their cable modem and my Asus routers with a Cogeco-supplied Arris TG3452 modem/router. I was also able to extend the incoming coax to a place in the house for better Wi-Fi coverage.
Installation and configuration of the router was quite straightforward, although its administrative interface is a bit unpredictable and cumbersome.
To date, I've had no problems and Wi-Fi coverage of the entire area I need seems rock solid. With a wired connection to the router, Speedtest is consistently reporting 20-23 ms latency, 945 Mbps down and 30 Mbps up (which will improve as Cogeco rolls out upload upgrades). Wireless performance varies with location of course, but I'm quite happy. I now have a much simplified network and don't need to worry about Wi-Fi pods,
1 - 4 of 4 Posts
