1 - 2 of 2 Posts
I am currently using a Scientific Atlanta 8300HD PVR with Videotron (Gatineau, QC). It’s getting old and will need to be replaced pretty soon. Although it’s a first generation PVR, I do like (and use) the “copy to VCR” option available on recorded programs. I’ve replaced the VCR with a DVD recorder and it works very well.
The problem is that more recent PVRs do not have that option anymore. The Videotron rep told me that it is in part because of legal and copyright issues. I personally think that this is nonsense; I should have the right to do whatever I want with what’s recorded on my PVR!
The Videotron rep hinted that it might be possible to record programs on a DVD recorder with the new generation of PVRs, but would not give any details. I’m looking at the Illico 4K Ultra HD (Samsung) since I just bought a 4K TV.
I imagine that I would have to connect the DVD recorder “in line” between the TV set and the PVR and record live programming, somewhat like we used to do with old VCRs? I wonder if the digital signals are compatible with this kind of connection.
Has anyone tried that setup with the Illico 4K PVR or similar (new) equipment? I’ve been reading various blog entries on your Web site, but, as far as I can tell, folks with problems refer to older equipment.
Thank you. :wink
Here's the FAQ on how to connect a DVD recorder and STB. Although you can put the DVDr "between" the PVR and the TV, you also obviously need a (parallel) direct connection from the PVR to the TV to get 4K.
http://www.digitalhome.ca/forum/30-57s-home-theatre-faqs/76077-faq-how-connect-vcr-dvd-recorder-stb.html
This, of course, assumes that the PVR has an output compatible with the DVDr (composite or S-Video, along with analogue audio?). I assume you realize that a DVDr records SD quality and that digital signals from the STB are not recordable. This is something that very few people bother with any more since the quality is SD and since the connections and hassle are rarely worth it. Also check out the following thread on CGMS-a (copy protection).
http://www.digitalhome.ca/forum/203-home-theatre-corner/44045-prevented-recording-vcr-dvd-your-digital-stb-please-read-first-post.html
It is possible to record using a Hauppauge HDPVR as discussed in the following FAQ utilizing component video and analogue audio connections (if available on the sending device).
http://www.digitalhome.ca/forum/30-57s-home-theatre-faqs/14099-faq-recording-hd.html
Useful Post: http://www.digitalhome.ca/forum/14-hdtv-high-definition-television-including-lcd-plasma/57741-hdtv-frequently-asked-questions-please-read-before-posting-forum.html
1 - 2 of 2 Posts
