81 - 100 of 104 Posts
Discussion Starter #81
Update
The RDR FM trap arrived ahead of schedule. I installed it and it had no impact on the signal quality for 7.1 and 11.1.
I hooked up my FM radio and continue to get FM music. Am I wrong to think this should not be the case?
Yes, as already pointed out by Rabbit73 you are wrong in that expectation. FM reception will not disappear entirely.
The best way to see how much impact the FM band has on your VHF TV reception is to measure it, before and after insertion of filtering, as pointed out in some of the links I posted. We also need to ensure any fm filter used is between the antenna and preamp input if using a preamp.
Not between the preamp and tv tuner.
Discussion Starter #83
I am not using a preamp. I am using a CM distro amp. I inserted it right before the feed to the distro amp. I also use a UHF VHF coupler before the distro amp. So I tried it first on the VHF feed into the coupler. Then I tried it on the combined UHF VHF feed out of the coupler that goes to the distro amp. The same results.
I have not tried it on the feed out of the distro amp. Not sure that would provide any different results. Assuming the FM trap is working then FM noise IS NOT the cause of losing signal quality on 7.1 and 11.1.
By the way the RDR FM trap had minimal impact on signal strength.
correct, leave it between the VHF antenna and the VHF port of the diplexer, or between the UHF/VHF Port of diplexer and the preamp input. Either way will sufficiently knock down the FM band, with minimal impact elsewhere.
"Insertion loss is less than 0.5 dB between 0 – 1 GHz"
Because you currently have no way to measure, u still can't quantify the true impact before and after inserting it.
The CM3414 (not sure if that is what ur using?) distro amps I have seen work OK around here.
From what I have seen FM band filtering is definitely needed on the CM3414 so leave it in place.
How long is the downlead from your antennas to the Distro Amp Input BTW?
IF you have a VHF/UHF Combiner prior to going thru Amp, I would recommend inserting FM Filter on Output of the Combiner so that it ALSO knocks down whatever FM signals are coming in via UHF Antenna....which can be quite a bit if you have strong FM signals. You would be surprised by how much Gain some/most UHF Antennas (& their Balun/Cables) have in FM Band....and we may need 20+ dB (maybe more) suppression.....
Discussion Starter #86
Majortom...yes I am using the CM3414 distro amp. Down lead to distro amp is about 20-25 feet for the VHF antenna and about 12 feet for the GH antenna (no top hat on it). At the moment no FM filter or trap in place. Have not seen any benefit from using it yet.
What I have not tried is putting the FM Trap on the output of one of the 4 CM3414 ports.
Hollands the output of my combiner is one of the places I tried the FM trap. My current UHF antenna is a GH w/o the tophats.
I going to keep playing with it.
You COULD try moving your antenna location to different locations to see if any better results. DO leave the FM trap in place though.
At my house just this spring, I had rearranged my antennas. I moved a VHF yagi to an eve mount, from chimney mount. And left the UHF antenna on the chimney mount.
When I was done, I no longer received VHF 8 from Toronto, about 70 to 75 mi distant. Literally moved it only 6 ft horizontally from the Chimney, to the eve mount, height was identical. Moved the VHF antenna back to the Chimney mount and put the UHF antenna on the eve mount instead...bam, RF ch 8 from Toronto was right back to the original Strength and Quality. Morale of the story, just a few feet one way or the other can make the difference between no reception at all, to solid reception. Thus when u have specific distant signals on ur must have list,
it's wise to do a signal survey of potential mounting locations before you commit to a permanent mounting location.
How do you get eve up on the roof and hold up the antenna for you? LOL
Discussion Starter #90
majortom,
Nice story. However was your problem caused by lack of signal strength, signal quality or both? I have plenty of signal but 0 quality. Seems strange that I get 100% signal strength on 13.1, 11.1 and 7.1 but 0 quality on 11.1 and 7.1 and 100% quality on 13.1.
Yes they broadcast from different locations but it's only a few degrees apart from my house.
I have 2 vhf antennas at different locations and they both have the same signal quality issue with 11.1 and 7.1. I have tried different orientations and the same results.
I continue to search for an answer. I am leaning on it is NOT FM noise but will still work on that angle. The only other thing that is fixable is maybe cell tower noise?
You don't really know what's going on in the VHF spectrum, because to date you haven't looked at it. I would get working on looking at the spectrum as discussed here.
The questions you wanna answer by looking at the spectrum... what is the noise floor doing? IS the signal buried in the noise, or is the signal above the noise and still not decoding?
When my VHF yagi was in the other position, it was definitely a lack of strength.
The same move a few feet one way or the other can get you out of multipath as well in some cases.
Yes Jorgek, the eave mount install WAS a little tricky to do despite 3 people,
"me, myself and I".
The strong signal may be from a source other than the TV signals. FM harmonics seem to have been ruled out so that leaves a puzzle. It's too bad that consumer grade tuners do not offer better diagnostics.
I had a similar issue with a 2 edge channel 13 signal here. That was compounded by power lines that created a lot of noise. With analog signals, interference could be seen and often diagnosed based on its appearance. I always had a watchable picture even if it did have some video noise. With digital signals there is no indication other than degraded signal quality and, depending on the tuner, sometimes not even that. That same channel, now digital and significantly weaker, often disappeared, probably due to EMI or tropo interference, and one day just disappeared. Never did figure it out. It just sat there at 70% signal strength and 0% quality unless tropo gave it a boost. I could easily see the signal on a spectrum analyzer and there was no indication of what was causing the issue.
Discussion Starter #93
Just a brief update:
I brought my antenna feed out of the distro amp directly into my Samsung TV and it was receiving 7.1 with an SNR (Per the TV Tuner of 16-17 with a lock). The picture was solid for the most part with a rare pixelation.
However still NO to 11.1.
So I checked the same feed into my DVR+ and the results were high signal but pic quality 0. No picture.
So somehow the tuner in my Samsung TV dealt with the situation better for 7.1.
Discussion Starter #94
Just another update.
So yesterday I put on VHF channel 7.1 and it was unwatchable as there was what appeared to be noise on the TV screen. I bought a new HLSJ a few weeks back and decided to give it a try. After I installed it VHF channel 7.1 was now almost perfect with some minor pixelation showing up from time to time.
So there must be some FM noise impacting 7.1. It was not all corrected but the filter helped a lot. Must be some noise still getting past the HLSJ.
11.1 is still a no go.
Premium Member
That's interesting. What is the make and model of the old HLSJ and the make and model of the new HLSJ?
You can now do a report from rabbitears.info using their new search map:
https://www.rabbitears.info/searchmap.php
This report is for your location:
https://www.rabbitears.info/searchmap.php?request=result&study_id=5840
This is an extract from that report:
You can click on Current Station Search List or Post-Repack Search List. In both cases 7 is stronger than 11.
I wonder which transmitting site are they actually using, the old ESB (Current), the new WTC (Post-Repack), or AUX and are they at full power?
https://www.rabbitears.info/tvq.php?request=items&facid=73881
If you click on Transmitter Distance in your report, a terrain profile will come up. Both signal paths are blocked by terrain, but the WTC path looks better:
Premium Member
Something is there that shouldn't be there, but we don't know what it is yet. I was hoping you could get an SDR dongle going as a substitute for a spectrum analyzer. I use my old Sadelco 719E signal level meter to listen to and measure noise on VHF. It is stronger on VHF-High than on UHF, and very strong on VHF-Low with an indoor antenna. The signal must be at least 15 dB stronger than the noise to be received.
I use a portable battery operated radio tuned to a clear frequency in the AM broadcast band to hunt for noise interference:
FCC advice:
Interference with Radio, TV and Telephone Signals
https://www.fcc.gov/consumers/guides/interference-radio-tv-and-telephone-signals
I asked you about your solar panels:
I see solar panels on your roof. Are they solar electric or solar thermal? If they are solar electric, I would suspect inverter interference.
You did say you had solar panels, but you didn't say if they were solar electric or solar thermal for heating:
lenlab said:
Yes I have had solar for the past 7 years and it never impacted my reception UHF or VHF.
Which kind do you have?
Discussion Starter #97
The first filter I tried was a Blonder Tongue ZHLSJ. The one I am currently using is a JVI 25-HLSJ.
Solar electric panels with micro inverters. They shut off when the sun goes down so if they were an issue I would get better VHF at night. Does not happen.
Premium Member
Thank you for the reply. Well, that eliminates those two possibilities.
The next thing to suspect is a high noise level on VHF.
Discussion Starter #99
An Update on my journey and experience. I bought an RTL-SDR USB device and then tried out software to get it working.
One caveat is I have no clue what I am doing and what the resulting displays are showing me with the various software discussed:
SDR# I loaded on my Win10 desktop with no issues and it seems to be working well. I can tune to various FM stations with a small portable antenna and hear them and see the results displayed. However it will be a challenge getting my antenna coax to this desktop.
SDR# loaded Ok on my old Dell Win XP Laptop but I could not get it to work. I can tune to an FM station but as soon as I try to make any changes to settings SDR# locks up and hangs the laptop. Only recourse is to power off. So it is not really working.
SDR Scanner was installed on the Dell WIN XP Laptop and it seems to be working well.
HDSDR is an application I don't see talked about here but it loaded on the Dell XP laptop and works. It seems to be a clone of SDR# as best I can tell with similar displays.
Finally I was able to download and install from the Linux repositories GQRX and have it running on my old Lenova laptop.
So there is hope for making use of old equipment even though there is not much support for Win XP these days as most developers have moved on.
Now that I have three computers with software I just have to get trained somehow on what the heck the displays are showing me. Besides having the ability to listen to a radio I am interested in analyzing my high VHF OTA signal for noise interference.
Premium Member
I bought the RTL-SDR.COM dongle and had to learn how to assemble the software to make a spectrum analyzer.
It was new to me also, so it took me many attempts to get it working. I selected the RTLSDR-Scanner software for the spectrum analyzer. SDR# and similar software is fun to use, but the dongle MHz bandwidth is too narrow to scan VHF-High. A spectrum analyzer program stitches together segments to cover the band.
You need the spectrum analyzer software for that. I learned how to assemble and use two 32-Bit programs and one 64-Bit program.
v1.3.2
rtlsdr_scanner-setup-win32.exe
https://github.com/EarToEarOak/RTLSDR-Scanner/releases
Channels shown above are 7, 9, and 13. Channel 9 (the middle channel) is marginal, it doesn't always have enough SNR to be 15 dB or more above the noise.
Simple earlier version; wait for popup (see Pete's post #47 on other forum)
rtlsdr_scan-windows-32bit.exe
https://sourceforge.net/projects/rtlsdrscanner/postdownload
if no popup
v1.0.22180.60082 next page
https://github.com/EarToEarOak/RTLSDR-Scanner/releases?after=v1.0.22617.26540
64 Bit v1.3.0 RTLSDR Scanner v1.3.0 (Pete's post #56 on other forum, not for XP)
rtlsdr_scan-windows-64bit.exe
https://github.com/EarToEarOak/RTLSDR-Scanner/releases/tag/v1.3.0
