Hi...I play mkv files fine no problem.Yesterday using Iskysoft Video Converter Ultimate I converted a m2ts file to mkv.The file originally was 4g after converted it was I think 10 or 12 gig I wanted to convert it to mpeg2 HD but it would have been like 24G.When i tried to stream the mkv file from my computer to the LG it says the format is not supported.I thought that was odd.I could copy it to the hard drive and check it but it is a big file.Played on my computer fine.Because I only have a P4 3.0 right now it took about 10hrs or so.I wanted to see how long it took to convert using Xillisoft video converter Ultimate and it sayed it would only take 2 hours to do to a mpg HD which would only be 10g or so.Which the other program said it would be 24g.One is faster and not as big as the output file either?
Anyone maybe know the reason for this?
What would be the best formate for conversion if there is one?
Should I be renaming the file?
I'm all new to this sorry for all the questions.
Any ideas or suggestions would be appreciated
