1 - 4 of 4 Posts
I have a Toshiba 24" CRT with Color Stream that I am trying to hook up using component cables to my DSR505. When I hook it up I either get a clear picture on SD channels and a scambled picture on HD channels or both on all channels depending on the DSR505 video settings.
My Tv manual says that I must turn satellite receivers output to 480i Interlaced mode or I will have poor picture or no picture. I have tried changing the video settings on the DSR505 but no luck. Anyone have a solution?
Use the hidden red button on the front of the 505. It is hidden behind a door on the front of the 505 just to the right. Keep pressing until 480i shows up on the front panel display.
1 - 4 of 4 Posts
