1 - 1 of 1 Posts
Hi Guys, I am new to this forum and I need help somehow making these work. These are all I have can somebody help me put them together without burning the receiver. I dont even know if the current receiver can handle this but other wise I will purchase a new one. I included the specs of the future receiver also. Whatever help I can get is appreciated.. Thanks a lot up front.
2 Aura Shaker 50 watts 4 Ohms
1 Dayton SA240-B 240W Subwoofer Amplifier with Boost (2 Aura shakers are conected to this amp) Powered 240 Watts @8 Ohms 150 watts @4 Ohms
1 Bose Acustimass Module 10 - 200Watts 8 Ohms
1 Buttkicker transducer 5 - 200 Hz 4 ohms 75 watts min. / 400 watts max. 1 ButtKicker Power Amplifier BKA300 the transducers are connected to this amp 300 watts @ 4 ohms 150 watts @ 2 ohms
1 Monster Home Theater StreamLine THX 100 Powered Subwoofer 120 Watts 4 Ohms
1 Buttkicker Quick Connect
Current Receiver:
ONKYO TX-SR602 Power Output* (8 ohm, 20 Hz-20 kHz, FTC) - Front L/R 85 W/Ch Center 85 W Surround L/R 85 W/Ch Surround Back 85 W Power Output* (6 ohm, 1 kHz, FTC) - Front L/R 110 W/Ch Center 110 W Surround L/R 110 W/Ch Surround Back 110 W Dynamic Power** (front) - 3 ohm 220 W/Ch 4 ohm 165 W/Ch 8 ohm 100 W/Ch THD (Rated Power) 0.08 % (all channels) Damping Factor (1 kHz, 8 ohm) 60 Input Sensitivity and Impedance - PHONO MM - CD and TAPE Play 200 mV, 47 k ohm Output Level and Impedance - TAPE REC 200 mV, 470 ohm PRE OUT 1.0 V, 470 ohm Frequency Response 10 Hz-100 kHz (+ 1 dB, - 3 dB) S/N Ratio - PHONO (MM) - CD/TAPE 100 dB (IHF-A, 0.5 V input) Phono Overload (1 kHz) - Tone Controls - BASS +/- 10 dB at 50 Hz TREBLE +/- 10 dB at 20 kHz
Future Receiver:
ONKYO TX-NR1007 THX™ Ultra2 Plus™ Certified 9.2-Channel Network Receiver Power Output - Front L/R 135 W + 135 W (8 ohms, 20 Hz–20 kHz, 0.05%, 2 channels driven, FTC) Center 135 W (8 ohms, 20 Hz–20 kHz, 0.05%, 2 channels driven, FTC) Surround L/R 135 W + 135 W (8 ohms, 20 Hz–20 kHz, 0.05%, 2 channels driven, FTC) Surround Back L/R 135 W + 135 W (8 ohms, 20 Hz–20 kHz, 0.05%, 2 channels driven, FTC) Front High/ Wide 135 W + 135 W (8 ohms, 20 Hz–20 kHz, 0.05%, 2 channels driven, FTC) Dynamic Power 320 W (3 ohms, 1 ch) 270 W (4 ohms, 1 ch) 160 W (8 ohms, 1 ch) THD (Total Harmonic Distortion) 0.05% (Rated power) Damping Factor 60 (Front, 1 kHz, 8 ohms) Input Sensitivity and Impedance 200 mV/47 k-ohms (Line) 2.5 mV/47 k-ohms (Phone MM) Output Level and Impedance 200 mV/470 ohms Phono Overload 70 mV (MM, 1 kHz, 0.5%) Frequency Response 5 Hz–100 kHz/+1 dB, -3 dB (Direct mode) Tone Control ±10 dB, 50 Hz (Bass) ±10 dB, 20 kHz (Treble) Signal-to-Noise Ratio 110 dB (Line, IHF-A) Speaker Impedance 4 ohms–16 ohms or 6 ohms–16 ohms
1 - 1 of 1 Posts
