1 - 4 of 4 Posts
Trying to connect purchased bell 6131 receiver using video switch box. Previous receiver (6141) had 3 connections the 6131 doesn't it just has one.
Any help?
You will have to be more specific in the question.
I thought both the 6131 & 6141 had the same Outputs and the only difference for Inputs is that the 6141 has an OTA Input, otherwise they are identical.
1 - 4 of 4 Posts
