1 - 5 of 5 Posts
Hi guys,
I have a 32" Digimate brand flat LCD TV (bought end of 2006). I've just borrowed my cousin's Playstation 3 to play games, we've tried to intall it but we failed. Is there anyway that we can install the playstation 3 on my TV?
By the way, my TV doesnt have an HDMI jack. It has the 3 RCA jacks instead.
Greetings
Does it have a DVI input? Sets of that vintage tended to have that too. If yes ... get a hdim to dvi cable and plug it in ...
or get the ps3 component video cable accessory to plug in.
Or get hdmi cable and buy a hdmi to dvi adaptor head...
or get DVI cable and buy dvi to hdmi adapter head
regards
· Super Moderator
If it failed I would guess that the PS3 was set to hdmi out only. With the PS3 connected to the tv, do a reset on the box by holding down the power button for five seconds. When the PS3 boots it will go to component out instead of hdmi. Of course you'll need the PS3 component cable (which it should have come with)
1 - 5 of 5 Posts
