1 - 6 of 6 Posts
I have a dual lnb bell dish and would like to wire 1 hd receiver and 3 sd receivers. How do I wire it and what switch would I need
sw24
Ok, change of plans from last thread. I have a dual lnb bell dish, I am using a cable from 91 and 82 to a switch 21 for my hd. I would like to run 2 sd receivers from the remaining 91 and 82 feeds, how do I do this. Can I use a sw24?
Attach the 2 x 4 switch to BOTH outputs of the 91 LNBF.
Feed 2 x SD Receivers from this switch.
Connect 1 output of the 2 x 4 and 1 output of the 82 LNBF to the SW21, feed to HD Receiver.
No problem.
1 - 6 of 6 Posts
