1 - 4 of 4 Posts
I have an itouch and need to sync it to a new computer (old one died), I have been told I can re-store my purchased apps and music but will lose my other music. I want to know if I will lose my contacts and calender?????? any help would be appreciated.
thanks.
I believe syncing it to another computer will erase everything on the iPod touch. As for purchased music note that Apple doesn't let you re-download songs.
Feel free to correct me if I'm wrong but I think that's what happens
(Edit: Before plugging in the iPod, disable auto synchronization. That should let you manually copy things back to your computer.
Not sure about this, since iTjnes is so complex. If you plug you touch into a new computer with iTunes installed of course, it shold ask you to transfer your purchases. You might first have to open the iTunes store and enter your Apple id.
1 - 4 of 4 Posts
