1 - 3 of 3 Posts
This post will show hard numbers on several of the
do it yourself uhf (no reflector) antennas.
Code:
Antenna                     Standard      Average Gain DB
                            Deviation       Per Channel
Flat Gain No Hybrid            .38             12.34
Centipede-4 Repack             .21             12.28
Flat Gain Hybrid               .45             12.07
SuperQuad Repack               .44             11.76
Mclapp 9.5 x 9 Repack          .59             11.51
SBGH Repack                    .70             10.47
With smaller standard deviations, the gain curve is more flat.
Hope this helps you decide, on which uhf antenna to build.
Have fun building antennas!
Discussion Starter #3 (Edited)
Here is the program code in freebasic for finding the average channel gain
It creates a text file with the standard deviation & average gain.
For those who don't want to bother with compiling this code, here is the executable.
ChanAveGain.exe
Freebasic code:
Code:
#LANG "fblite"
DECLARE Function Remain$( ByRef nStart%, ByRef sMainString$, ByRef sMatchPattern$)
DECLARE Function Extract$(nStart%, sMainString$, sMatchPattern$)
DIM ChannelGain!(14 TO 36,2)
DECLARE SUB Incr(A%)
' Enter filename
Cmd$ = COMMAND$
IF Cmd$ = "?" OR Cmd$ = "-h" THEN
        PRINT "ChanAveGain Filename"
        SLEEP
        END
END IF
OPEN Cmd$ FOR INPUT AS #1
InputFile$ = Extract$(1,Cmd$,".")
OPEN InputFile$ + "-Freq-Chan-Avg.txt" FOR OUTPUT AS #2
PRINT "Getting Average channel gain"
PRINT "Working"
FOR I% = 14 TO 36
    INCR TotalChannels%
    DO
        position& = SEEK(1)
        LINE INPUT #1,Thisline$
        FirstChar$ = LEFT$(Thisline$, 1)
    LOOP UNTIL FirstChar$ <> "#"
    SEEK #1,position&
    TotalChannelGain! = 0
    FOR J% = 1 TO 6
        Gain$ = TRIM$(REMAIN$(1,Thisline$,CHR$(9)))
        TotalChannelGain! = TotalChannelGain! + VAL(Gain$)
    NEXT J%
    TotalChannelGain! = TotalChannelGain!/6
    ChannelGain!(I%,1) = TotalChannelGain!
    ChannelAvgGain! = ChannelAvgGain! + TotalChannelGain!
NEXT I%
ChannelAvgGain! = ChannelAvgGain!/TotalChannels%
TotalChannels% = 0
Variance! = 0
FOR K% = 14 TO 36
    INCR TotalChannels%
    ChannelGn! = ChannelGain!(K%,1)
    Variance! = Variance! + (ChannelGn! -ChannelAvgGain!)^2
    ChannelGain!(K%,2) = (ChannelGn!-ChannelAvgGain!)^2
NEXT K%
Variance! = Variance!/TotalChannels%
StandardDeviation! = SQR(Variance!)
PRINT #2,"Standard Deviation = ";TRIM$(STR$(StandardDeviation!));"    Average Gain = ";TRIM$(STR$(ChannelAvgGain!))
PRINT
PRINT "Standard Deviation = ";TRIM$(STR$(StandardDeviation!));"    Average Gain = ";TRIM$(STR$(ChannelAvgGain!))
SLEEP
END
SUB Incr(A%)
A% = A% + 1
END SUB
Function Remain$( nStart%, sMainString$, sMatchPattern$)
    nLenMain% = Len(sMainString$)
    If (nStart% = 0) Or (nStart% > nLenMain%) Then Return ""
    If nStart% < 0 Then nStart% = nLenMain% + nStart% + 1
    i% = Instr(nStart%, sMainString$, sMatchPattern$)
    If i% Then
       Function = Mid$(sMainString$,i%+Len(sMatchPattern$))
    Else
       Function = ""
    End If
End Function
    if (nStart% = 0) Or (nStart% > nLenMain%) Then Return ""
    If i% Then
       Function = Mid$(sMainString$, nStart%, i%-nStart% )
    Else
       Function = Mid$(sMainString$, nStart%)
    End If
End Function
1 - 3 of 3 Posts
