Reflector Mod, completed...
Well, I've been reading this channel for quite some time now and decide to do the reflector hack. I cut back 2 inches from each side of the antenna, that proved a little difficult - spent a couple of hours as I didn't want to bend anything out of whack - yeah right.
So I managed to cut all the bars, reset the plastic supports - I think I may have bent the antenna a bit. Any how, I am currently using the antenna indoors (waiting for my roof to be redone before putting it up there) and the results are mixed.
The channels I have managed to retain are solid and actually appear much richer, indicated low signal strength seems to be holding better than before, but I lost a couple of channels...
Can anyone provide the technical measurements of the antenna, i.e. how far the whiskers should be from the reflector, how wide the spread should be for the whiskers - that sort of thing. I want to make sure my hack job didn't put the antenna to far out of spec.
I haven't tried the other hacks, balun or plastic cover removal, with this mod yet, although I did do those hacks initially (before the reflector mod) and saw no significant improvements...
