So, the confirmed word is this next code will begin distribution early next week. Beginning with a Modem update on the 13th, the main code push will start on the 14th and will take up to 4 more days to work through to all boxes. Updates should happen between 2 and 6am local time.
The modem update cannot be 'postponed' and so any recordings that might be happening in the wee hours will be split and missing a few minutes. The code update can be postponed if you happen to be watching when the update wants to complete.
Details of what the code will bring are sketchy yet but include PPV recording support and the ability to delete folders that have more than the previous 35 recordings in them. As I have reported in the previous code thread, the grid guide is supposed to be much improved for navigation and the 'blanking' issue should be solved. DLNA, while not immediately available, is part of this code release and will be enabled in the not too distant future.
The new 'Super Ticker' will be turned on tomorrow and, while it is billed as part of the 7.0.4 code, it clearly is a separate item since it is being activated prior to the code release.
As always, I'll post more details as they become available.
OTHER USEFUL THREADS
Fixes & issues
If you're having a problem with the Shaw Gateway, please see if it has already been reported before posting. (This is a running list. Not a discussion thread.)
http://www.digitalhome.ca/forum/showthread.php?p=1324303
Adding external drives
http://www.digitalhome.ca/forum/showthread.php?t=142528
Wait times for Gateway support
http://www.digitalhome.ca/forum/showthread.php?t=145274
Installation and setup
http://www.digitalhome.ca/forum/showthread.php?t=145834
Programming universal Harmony remote for use with Gateway
http://www.digitalhome.ca/forum/showthread.php?p=1331570
Fixes & issues
