Channels go black
1161 Views 2 Replies 3 Participants Last post by  57
I have Eastlink Digital Cable, and more often than not (as of the last few weeks), I'll be watching TV and all of a sudden the screen goes pink and fuzzy for about one second then goes black. My cable box stays on, it still says the channel and if I press anything on the remote the light flickers on my cable box so it still responds, but just won't show a picture.. On occasion if I fiddle with the cable cords and unplug it, plug it into my modem, plug it into the tv, etc. I might get my cable back, but it's only temporary.
Any ideas?
1 - 3 of 3 Posts
Yeah call Eastlink tech support. Eastlink can diagnose your issues and send a tech out if necessary.
Pink colour is often an indication of a poor connection. Please provide us with the makes/models of all your equipment and which connections you're using.
Here's a key to the connections:
http://www.digitalhome.ca/forum/showthread.php?t=76085
Here's a list of things to check:
http://www.digitalhome.ca/forum/showthread.php?t=19694
Black Channels may also be a poor signal. Here's the FAQ on checking signal, which your provider can also do.
http://www.digitalhome.ca/forum/showthread.php?t=21274
Once you get things sorted out, check out the following useful post:
See less See more
1 - 3 of 3 Posts
