Going to pull the 3023 out of storage and try it at a new location. I have a house in an area where I have some weak signals for channels 26 and 30. NM is around plus 2 to to 3 for each and both are 2 edge. Multipath prone area since it is is an urban area with lots of taller structures within a few blocks to a mile and also some large trees in the vicinity.
Currently using a MXU 47 which can get a whiff of these signals at times but won't lock onto them according to my TV. Need 15 to 15.5 db reading on the signal strength meter to get a lock and watchable picture. Right now they signals are hovering under that around 10 to 12 db.
If I add some hardware cloth to the reflector of the CM 3023 can I improve the signal strength on each of these channels? If so, how big should each piece be for top part and bottom part of the reflector? Will using cable ties to attach to the reflector impact the signal?
