1 - 4 of 4 Posts
Once in a while... I lose my channel lock programming.
Is this normal? Thanks
No it is not normal, I would suspect low Signal Levels.
My signal is over 90%... And most of the time the ones that unlock are under channel 100 and all the NHL/NFL channels
Ah, you mean the Channels locked out in the Guide, not the actuall Signal Lock....
I have ALL French locked out, never have an issue, everything from the beginning upto 197, plus Adult, PPV etc, works fine.
1 - 4 of 4 Posts
