1 - 20 of 28 Posts
Hello everyone.
I recently had MTS Ultimate TV installed (switched from Shawdirect).
Overall I am happy with the switch. I love having 3 TV's hooked up, and having the Whole Home PVR.
However, there are some things that I preferred with Shaw Direct. I was hoping we could use this thread as a place to capture things we wished were changed or improved with MTS Ultimate. Maybe some of the things we wish for are already offered, but we don't know about them?
Also, maybe the guys who know Mediaroom can let us know if some of the suggestions are technically possible or not?
Here are somethings that I wished MTS TV had:
1) The ability to handle the SD and HD feeds separately. By this I mean with Shawdirect I could have my SD channels stretched to fill the width of my TV, and I could leave the HD channels alone. With MTS, there is no such functionality. I can change the setting on my TV, but that changes it for both SD and HD, which is no good.
2) The ability to put a "reminder" or "switch to" tag on a channel for a show at a later time. With Shawdirect I could tag a show that is going to play at say 8 o'clock, and have box would either give me a reminder when it was 7:59, or automatically switch to the show. It's not a huge thing, but I liked the feature.
3) Not a big deal for me, but my wife liked the color coded Shawdirect Guide. Would it be possible to add an option to make the guide color coded? (I.E. sports = green, movies = blue), etc.
Anyone have any others?
1) If you press the "Enter/Aspect" button there is a menu called Aspect, you can change the aspect to stretch, Zoom1, 2, 3. It applies to all channels though both HD and SD. but it is better than changing the TV settings.
2) Auto-Tune has been discussed before, there is no feature in Mediaroom for that.
3) No colored guide in Mediaroom
I would be happy with any or all of these features, they would be a great addition to the service.
I believe that if you choose stretch it only does that for the SD channels, as the HD channels already fill the screen. If you do choose the zoom modes, it does zoom in for both HD and SD.
Yeah, and the thing that some people still find annoying is that if you are watching an SD show on an HD channel, you still get black bars on the sides because you can't stretch it (though zooming it might fix it, but then you're cutting off something else)
Discussion Starter · #10 ·
I just used the stretch feature and that is exactly what I was looking for, thanks!
It stretched the SD, but left the HD alone.
1 - Set/change PVR setting from a smartphone.
2 - Stream content to a smartphone.
3 - PC as a STB.
4 - XBOX 360 as a STB.
5 - Ability to add more storage.
6 - Ability for the box to figure out if the overall preventing recordings is limited to over runs (ie 1 minute of three shows due to one ending at 9:01 pm and two others start at 9:00 pm).
1. for recording a series, the ability to only record on a certain day.
2. a couple more channel lines in the program guide, maybe 2-3
3. auto enable/disable channels depending on subscription, ability to over ride as well
4. smartphone app
5. bring back colors in the program guide
6. ability to change channel order
7. another hd stream
8. ability to READ from a USB stick to play movies
Just had the service for 1 week but here is my 2 cents:
1.HD channel numbering. I find it is very messy the way they are setup. They should be grouped by package with gaps for future channels.
2.Timer Auto tune. I like waking up in the morning and turning on the TV to a certain news channel.
3.Guide transparency: allow an option to disable a transparent guide. I find it can be hard to read depending on room lighting.
4.Delay in pressing guide button to when it is shown on the tv. I notice a 3-4 second delay.
5.A guide option (by selecting guide again?) to only see subscribed channels. Would be a very nice feature.
Bunkhouse:
With regard to #5 on your list, if I'm understanding your comment correctly, it is possible to remove channels from the Guide.
Menu > Settings > Television > Customize Channel Guide
I hope that helps.
yes that is possible. but the navigation is very slow, and that was prior to the fiasco of the latest update, which has imposed a 3-4 second delay in the pvr receiving the remotes commands. Must be due to high sunspot activity in my living room, or maybe its dark matter.
what he is talking about is the same that i posted. why cant the pvr automatically pick up the channels that you are subscribed to? so instead of having to go through each channel individually to find what you want, only show what you actually have, with the ability to customize from there?
i my self was extremely happy with the service prior to last update, but find that the new 'enhancements' really piss me off. nothing like an unresponsive remote, that after 12 seconds decides to react to EVERY command that you sent to the PVR, that it had ignored. stupid last channel 'feature' is retarded. the new aspect ratio is no longer any good. nothing like having to spend a good 30-40 seconds to change the aspect ratio that used to take 5 seconds.
not really sure who the idiots are at MTS who come up with these new 'enhancments/features', they obviously do not even use MTS tv, as they would have seen within the first 5 minutes, how stupid they are.
you do realize that MTS has probably next to nothing to do with the "enhancements" when I start reading about what Telus and AT&T customers are having for problems it is pretty evident that it is a Microsoft issue.
I know that is hard to believe since Microsoft never causes problems with updates to it's software :p LOL. Still from what I keep reading here and on the AT&T forum I would have to venture a guess that whatever the issues Microsoft is likely getting an earful to fix things
@Don J, I found that if I customize and remove channels, those channels don't show up when I do a search. This cuts down on the search results if you remove channels you don't subscribe to or don't watch.
For example, if you have an SD TV and remove the HD broadcast networks, they won't show up in the search results. Conversely, if you have an HD TV and remove the SD "duplicate" channels, you won't see them in the searches. You can also remove the timeshift channels you don't subscribe to and remove the clutter.
1 - 20 of 28 Posts
